Main scene FTBE v 1.3.4
Hello everyone!
NEW version is OUT!
More about scene and download you can find here:
WHAT'S NEW:
  • Main scene FTBE 1.3.4 - changed function for time of day calculation and added use of SleepState global to set time of day to morning when Awake  regardless of current time
  • Main scene FTBE 1.3.0 - cleaned some bugs, added some more checks to prevent scene from stop running due to errors. Optimized and compacted code, removed unnecessary comments. DemoMode only stops changing timers while user code and scheduled events will continue to execute. Darkness can now be changed by measured lux level or global variable that is set to lux value measured by light measuring devices placed outside. Scene is now running on setTimeout function instead on sleep for better timing and also aligns to 0 seconds or exact minute.
  • Sunrise & Sunset VD v1.4.0 - Modified main loop code to better handle global variables. Variables are now automatically repaired and are not reset to default settings after HC2 reboot. Added variable SunriseIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically.
  • Home Status VD v1.1 - Added variable HomeStatIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically. Added label that shows most important values on VD when closed.
  • Home Timers VD v1.1 - Added variable HomeTimersIcon to store VD icon ID and now when main icon for VD is set also all button icons are set automatically. Added label that shows most important values on VD when closed.
NOTE - This version is compatible with previous versions so need to do any changes in your current code of other scenes and VD's.
REQUEST - If you like my work and found it useful please give me support by rating and writing short review. Thank you! :-)
PS
Dear friends from Slovakia you can find this scene and VD translated to your language here:
Edited by Sankotronic
Updated to new version
  • Like 16
  • Thanks 6
Just now, Sankotronic said:
Hi @Bodyart,
I give up on further coding of that part since Fibaro location service was and still is not so usable. When location services are turned on for Fibaro app it just drains battery and occasionally it jumps for more than 100 meters and that is not good. Thanks for this code and I can incorporate it in next release.
This is in the first place mine LUA learning :-) That's why I'm "playing" with different scenes an devices published here in order to understand the code. Sometimes it gives result too :-)
    Yep, that is the best way to learn! I learn a lot form examples and others work and advices. But of course from time to time I also consult book Programming in LUA check here:
     I have 3rd edition :)
    Is the implementation of Fibaro LUA a superset to std LUA, as far as you're aware?
    To be honest I didn't yet go that deep so don't know how much of standard LUA is included on FGHC.
    VDs run Lua 5.2 and scenes run 5.3. I don't know the exact list, but several parts of Lua have been disabled. Most notable ones: os.exec, debug, require, loadfile, coroutines. Extensions are http, setTimeout, the HC api and json.
    Wow, You must be highly educated!
    Thank you very much.
    Thank you for the compliment...
    Another example
    I save calendar event into variable and then using this code in function extraUserCodeFirst()
    Variable does look like this:
     Code will split the date, time and event to 3 parts
    On ‎10‎/‎12‎/‎2016 at 8:09 PM, Sankotronic said:
    "HomeTable"       - predefined global variable table with device and scene IDs. Recommended to use since z-wave devices can change their ID with re-inclusion and then is necessary  to edit only scene which make this table and only device ID in scene headers. Much less time and effort is needed than without that option! So if you use this table then uncomment line bellow:
     Hi
    I warn you that you need patience with me please <grin>.  I am just no good at coding languages. From your statement above, I understand to go to the lower section on the Variable Panel and I have to create the "HomeTable".  But what the content of the table should look like is where I hit a blank.  Can you please show me an example with a few "records" in it.
    Thanks for all the work you put into helping rookies like me.
    - INSTALLATION INSTRUCTIONS
    IMPORTANT!
    1) Please first download "Sunrise & Sunset" VD and import to your HC.
    2) Create new LUA scene and copy and paste code. Save to start scene and check debug window for any errors. If all good it should look like this:
    Your look like the snapshot above and mine is as per my snapshot
    I apologise if it has been dealt with in the following 15/16 pages of posts.  If so, then I will just have to hunt for it
    Thanks a stack
    @lennypenny, for HomeTable concept you have link there:
    Generally you create global variable ( deep structure ), where you name each device, scene, controller. This way you do not have to remember ID`s or change code if device is reconfigured (new ID). You use only structure path to point device.
    Of course scene "HomeTable" should be executec after HC start so it can load variables.
    Below part of by code so you can get idea:
    Can you post what exactly you have in line 924 ? Please past few lines before and after it.
    Edited by Bezan
    Thanks Bezan, for the instant info
    Something odd.........  I followed the instructions to set up HomeTable and then came back to your question.  It has changed without me doing anything in that scene.
    see:
    I have not seen so many feedback lines and also not seen the "DEACTIVATE" button
    I also cannot seem to change the Weekday and Month.  It simply does not tick over
    see:
    Any ideas?
    Hi @lennypenny,
    Main scene is running but since Demo mode is turned On scene is not changing any global variables or running any scenes or VD that are setup to run repeatedly or scheduled. You need to use Home Status VD to turn off Demo mode.
    Regarding Timers VD, do you mean that pressing button does not change weekday and month?
    Anyway, I just finished and posted New Weather State VD and Netatmo scene so now I'm working on new version of Main scene and accompanying VD(s) since ti is core of the system and needs refreshment! :)
    Hi Sankotronic,
    Thanks for the info.  I have changed Demo mode to "NO"
    Yes I click on the buttons and it does not change weekday and month.
    Please see the new snapshots after I changed the Demo Mode
    Thanks for your help
    hi @lennypenny,
    i had the same issues like you. In 99% of the cases I had wrong or missing Variables.
    Go through again the install instructions, some of the variables are only mentioned in the text. Also the update notes at the beginning of the 1 post.
    Not all Variable are mentioned in the list 1 - 6!
    Also the VDs you installed need attention. In the Timers VD i adjusted the slowakian(?) names for Days, Month and so on.
    Just go through the code in advanced tab. you will see it quite fast there.
    Again: check the variables and their content. Names and values have to match 100%.
    I add a screenshot all of them are needed for Time based szene + timers VD + sunrise VD + home status VD.
    Very important: you can't set the values of the upper part correctly using the variables screen. they have to be set using the VDs / scenes.
    Therefor your timers + sunrise VDs have to work properly. Only then the time is set correctly into the variables. (E.g. DayTime = 09:00 instead of 09)
    good luck, kro
    ps: @Sankotronic: genius
    Edited by kroeatschge
    Quote
    Hi @
    Thanks for the pointers.  I will chuck it and begin again I think
    L
    Working hard on new version of Sunrise & Sunset VD and Main scene for time based events. I just can't leave it like this that global variables are destroyed if user press Save button in variable panel so next version will not have that very big disadvantage.
    Also if I manage to use new solution for setting up predefined variables using different languages, then setup will be even more simple.
    Great @Sankotronic, keep up the good work! Your scene for time based events is a beauty, a real beating heart!
    Hvala liepa
    19 minutes ago, lennypenny said:
    Hi @
    L
    Hi @lennypenny
    I posted this on another topic but I thunk it's good advice and worked well for me
    my mantra always is 'keep it simple' if possible...
    Testing this nice Main scene for time based events control, but just ran into a question.
    Is it possible to setup to run a scene every 5 min between a defined clock interval like 21:00 to 23:00?
