Start a scene when the tv is turned on with normal remote
I successfully integrated my Samsung tv. Can now control it through Fibaro. Don't really see the use of it though.
What I'd like to do is have a scene start when the tv is turned on through a normal remote. FYI: the scene will check daytime, if it's day it will close the blinds, if it's evening it will set the lights at a dimmed level, etc...
Possible?
Thank you,
apgc
5 minutes ago, Bodyart said:
Frank, I'll share everything that is tested and working, even when the code isn't clean and structured :P
@Bodyart
That would be great
51 minutes ago, Bodyart said:
iTach Flex is a wi-fi device.
hi @Bodyart,
The deed is done.  I have just ordered the WiFi Flex version.  Now I wait and then I guess, stress starts
1 minute ago, lennypenny said:
hi @Bodyart,
To easy your stress you can download in the meantime iTAch application iLearn (
and
), that is used to read the code sequences from all your IR-remotes. Althought iTach has a huge database of devices and their code sequences, not all devices I use were there.
and
@lennypenny
@Bodyart
I have the same experience and found it faster and sit with a remote and learn all the buttons
