fondoftri 0
I would like to create a scenne called "sleep time" which is invoked by amazon's Alexa by saying "Alexa turn on sleep time". The purpose is to turn bedroom lights off and switch off my Kld-40hx750 Sony Tv by sending the http post protocol (text/xml) to the TV like in attached Foto (the one is working example where I switch my tv to netflix by saying "Alexa, turn on Netflix" (to turn tv off the code is the same with the only difference in the string "AAAA..."). The Problem I have is that I can not send to Fibaro the Get Method (text/html) to turn the lights off (second Foto) and in the same time http post (text/xml) using HA Bridge (perhaps I'm wrong?). Therfore I was thinking to run the scene in Fibaro to turn the lights off simple calling function "fibaro:call(ID, "turnOff")" but the Problem remain with sending the http post protocol to the TV. I have read this can be done by making VD and sending http Protocol over it. Any help would be appreciated.
Edited by fondoftriLink to comment
