Tutorial - Using a Hometable to store device and scene ID's
Ok, here is my full scene, "Make HomeTable".
%% autostart
%% properties
%% events
%% globals
local debug = true --set to false to stop debug messages
-- HOME TABLE FOR ANYTHING IN ADDITION TO DEVICES, VDs, iOS DEVICES
-- EDIT TO YOUR NEEDS OR KEEP BLANK: jsonHome = {}
jsonHome = {MainScene=106}
-- NO USER EDITS NEEDED BELOW
local function log(str) if debug then fibaro:debug(str); end; end
devices=fibaro:getDevicesId({visible = true, enabled = true}) -- get list of all visible and enabled devices
log("Fill hometable with "..#devices.." devices")
-- FILL THE HOMETABLE WITH ALL VDs, DEVICES AND iOS DEVICES
for k,i in ipairs(devices) do
 deviceName=string.gsub(fibaro:getName(i), "%s+", "") -- eliminate spaces in devicename
 if fibaro:getType(i) == "virtual_device" then -- Add VDs to Hometable
  if jsonHome.VD == nil then -- Add VD to the table
   jsonHome.VD = {}
  jsonHome.VD[deviceName]=i
  log("i="..i..", type="..fibaro:getType(i)..", device="..deviceName)
 elseif fibaro:getType(i) == "iOS_device" then -- Add iOS devices to Hometable
  if jsonHome.iOS == nil then -- Add iOS devices to the table
   jsonHome.iOS = {}
  jsonHome.iOS[deviceName]=i
 else -- Add all other devices to the table
  roomID = fibaro:getRoomID(i)
  if roomID == 0 then
   roomname = "Unallocated"
  else
   roomname=string.gsub(fibaro:getRoomName(roomID), "%s+", "") -- eliminate spaces in roomname
  if jsonHome[roomname] == nil then -- Add room to the table
   jsonHome[roomname] = {}
  jsonHome[roomname][deviceName]=i
  log("i="..i..", type="..fibaro:getType(i)..", device="..deviceName..", room="..roomname)
jHomeTable = json.encode(jsonHome)    -- ENCODES THE DATA IN JSON FORMAT BEFORE STORING
fibaro:setGlobal("HomeTable", jHomeTable)   -- THIS STORES THE DATA IN THE VARIABLE
log("global jTable created:")     -- STANDARD DEBUG LINE TO DISPLAY A MESSAGE
log(jHomeTable)
-- I then like to read back a entry from the table to show that the table didnt get corrupt in the process.
local jT = json.decode(fibaro:getGlobalValue("HomeTable"))  -- REFERENCE TO DECODE TABLE
log(jT.System.MainScene)      -- DISPLAY ONE VARIALE
Here is parts of Debug (not pasting every device):
[DEBUG] 15:02:26: i=304, type=com.fibaro.FGWP101, device=NVidiaShield WP, room=USLivingroom
[DEBUG] 15:02:27: i=305, type=virtual_device, device=Sunrise&Sunsetv1.2
[DEBUG] 15:02:27: global jTable created:
[DEBUG] 15:02:27: {"GFComputerroom":{"Ceilinglamp":61},"GFBedroom":{"Alarmsensor":205,"TemperatureSensor":206,   **** And so on ****
[DEBUG] 15:02:27: nil    **** The last line ****
Link to post
  • Replies 154
  • Created
  • Last Reply
Top Posters In This Topic
Hi, This tutorial is based on an idea that i believe originated to @cag014 some time back and has been adopted by many. So well deserved kudos to @cag014 and others that helped originate and
Wow, nice to see so much traction on this post/thread! @Momos, sorry have been away/busy, but your question to add section info triggered some more elaborate thoughts and suggestions, in additi
Here's another version that automatically adds users and scenes too. All room/device/scene/etc names are converted to lowercase (except the mobile device name so it can be copy/pasted from the Access
System is something that does not exist in above lua.
Try:  log(jT.GFComputerroom.Ceilinglamp)
Edited by riemers
remove whitespace
Link to post
%% autostart
%% properties
%% events
%% globals
   jsonHome.VD = {}
   jsonHome.iOS = {}
  if roomID == 0 then
  else
log(jHomeTable)
okay try this, change only to second last line
%% autostart
%% properties
%% events
%% globals
jsonHome = {}
   jsonHome.VD = {}
   jsonHome.iOS = {}
  if roomID == 0 then
  else
log(jHomeTable)
log(jT.GFBedroom.Alarmsensor)      -- DISPLAY ONE VARIALE
Link to post
Ahhh... Then it gives result:
[DEBUG] [time]: 61
Which indeed is it's number :) Thank's!
Link to post
[DEBUG] [time]: 61
Success !!! :-)
So the table is being created and you can now use it.
 - Watch the case sensitivity when referencing table elements, it has to match exactly..
It might be worth keeping a full copy of the table in something like Notepad++ or your editor of choice
That will make it easier to reference when writing new code
happy coding ..
-f
Link to post
Thank's a lot @AutoFrank, @riemers
Next step: node-sonos-api or HomeKit on my new Pi 3. That will have to wait til the weekend, though :)
that a great thing about HA.. never short of challenges .. just time :-)
Link to post
@robw Going bit offtopic, but might i suggest you use docker for that. Some nas systems include docker too (synology) from the gui. Using docker is easy and simple to give to someone else too, work on Pi3 too. For node-sonos-api there is a docker image https://github.com/chrisns/docker-node-sonos-http-api saves you the hassle of installing all dependency's, assuming you have some knowledge with linux.
Link to post
Thank you! I will test the docker version :)
Cheers,
Link to post
3 hours ago, robw said:
Thank's! I will spend time reading about it, and implementing it :)
Cheers,
Good luck with it :-)
Link to post
@Momos, sorry have been away/busy, but your question to add section info triggered some more elaborate thoughts and suggestions, in addition to the comments from @AutoFrank
9 hours ago, Momos said:
Yup. They already have 'smart' names like living.xxx.xxx but there is no room to make names even longer.  Besides rooms, there are also the sections- for example i have defined section 1 ground floor, section 2 first floor, section 3 third floor.
I know you can get through the api the section number to which a certain device belongs to.  But i'd like the reverse: to automatically make the table with all the PIRs in section 1 and all the blinds in section 1.
I have these tables set up now manually. Was wondering if there is any way to do it automatically.
  1. Although it does not solve your ‘section’ request, there is also a nice new LUA function you can call to get the device ids for a filtered set of devices: fibaro:getDevicesId. These have nothing to do with this whole HomeTable concept, but may be an easy way to make some custom selections you need for your purpose. See the below code as an example of how you could use this:
    local data =
            interfaces = {
              "light",
            properties = {
              dead = false,
            enabled = true,
            visible = true,
            roomID = 4,
    ids = fibaro:getDevicesId(data)
    fibaro:debug("devices reported by fibaro:getDevicesId: "..json.encode(ids))
    Be aware that the filters act as an AND operator, so you cannot select e.g. multiple rooms in one go (e.g. if you change the line to roomID = {4,5} you get an empty table as a return as no devices are in both rooms). So this does not help for your section challenge…
  2. The other option is to use the API command to extract the section information, as you indicated. See the post below for a python script which could be adapted to include section fields (through the <hc2>/api/sections commands)
    https://forum.fibaro.com/index.php?/topic/20634-sunset-and-sunrise-why-doesnt-this-work/&page=2#comment-106531
  3. …But your ask was if one could do this in the LUA script. Not so easily…but I got there in the end :-). The only section related info you can extract with the fibaro LUA commands (i.e. not using the API) is to extract the section ID: fibaro:getsectionID(deviceID). So, some manual configuration is needed to map the sectionIDs to the section names you prefer in your hometable. I had a stab at it, see the code below, hope this is in line with your needs. The mapping is done in the sectionNames table which you need to update to your situation. Also you need to list all the deviceTypes in your system, it will throw an error if one is missing:
    %% autostart
    %% properties
    %% events
    %% globals
    local debug = true
    -- Name of your sections. You also need to update the numbers in square brackets
    -- You find these by typing <HC2 IP address>/api/sections in your browser
    local sectionMapping = {[4]="GroundFloor", [5]="FirstFloor", [6]="SecondFloor",[7]="Garden"}
    -- Map your device types to some easier names for your table. Adapt as you wish
    -- You need to strip out the dots in the types, otherwise it will not work in the table
    local deviceTypes = {
    	comfibaromotionSensor = "Motion",
    	comfibarotemperatureSensor = "Temperature",
    	comfibarorollerShutter = "Blind",
    	comfibarobinarySwitch = "Switch",
    	comfibaroFGWP101 = "Plug",
    	comfibaromultilevelSwitch = "Dimmer",
    	comfibarothermostatDanfoss = "Thermostat",
    	comfibarosetPoint = "Thermostat",
    	comfibarolightSensor = "Lux",
    	comfibarohumiditySensor = "Humidity",
    	comfibaroFGD212 = "Dimmer",
      	comfibarophilipsHue = "Hue",
    	virtual_device = "VD",
    	comfibaroFGRGBW441M = "RGBW",
    	comfibaroremoteController = "Remote"
    jsonHome = {}
    	if fibaro:getRoomID(i) ~= 0 then -- only devices that are allocated to a room as otherwise there is no section
    		sectionID = fibaro:getSectionID(i)
    		sectionName = sectionMapping[sectionID]
    		deviceType = deviceTypes[string.gsub(fibaro:getType(i),"%.","")]
    		if deviceType == nil then
    			fibaro:debug("Add " ..string.gsub(fibaro:getType(i),"%.","").. " to the deviceTypes table!")
    		if jsonHome[sectionName] == nil then -- Add section to the table
    			jsonHome[sectionName] = {}
    		if jsonHome[sectionName][deviceType] == nil then --add type to the table
    			jsonHome[sectionName][deviceType] = {}
    		jsonHome[sectionName][deviceType][deviceName]=i
    		log("i="..i..", name="..deviceName..", type="..deviceType..", section="..sectionName)
    log(jHomeTable)
  4. As a further thought: nothing stops you to have the same device ID in multiple branches of your hometable. What I mean is that you can combine the ‘room-->devicename-->deviceID’ structure from my original script (in the first post) with the ‘section-->type-->dvicename-->deviceID’ structure from this script to get a more extended table to have the best of both worlds. Just combine the two scripts to get a more extended table with room-->devicename-->deviceID as well as section-->type-->deviceName-->deviceID
Best, Rene.
Link to post
Rene, I think this is exactly what i was looking for. Thank you.  Will try it and confirm in about 10 days when i get back home.
Link to post
Good to hear, and thanks for the challenge/request ;-). Indeed, please let me know if this work well for you.
Link to post
Hmm.  Is there a length restriction on a global variable?  The jHomeTable looks right (see below, I have added line breaks for ease of reading. I have inspected it in Visual Studio and it is syntactically correct LUA), but jT=nil in the second last line.  No variable gets created in the Variables Panel.
EEDIT:  Solved it (I think) the problem is in having rooms or devices like "Boy's Room".  The apostrophe (') is maybe treated as the end of the string?
jHomeTable: = {"BottomStairs":{"MotionR":250,"LightR":255,"TempR":251,"EntranceDoor":181},
               "VD":{"LaundryExhaustTimer":66,"Sunrise&Sunsetv1.3":308,"WineCellar":69,"GarageDoor":189,"StandardLampLED":223,"HomeCentre2":285},"FrontDeck":{"FrontDeck":90},
               "Garage":{"GarageFreezer":27,"GarageDoorSensor":266,"GarageDoorOpener":183,"LightX":235,"TempX":231,"MotionX":230,"GarageDoorPanic":185},
               "Controllers":{"WeatherProvider":307,"YahooWeather":296,"WhiteMinimote2":282,"Vera3Controller":43,"WhiteMinimote1":284,"RFIDKeypad":303,"BlackMinimote":121},
               "Boy'sRoom":{"SonosPlay1":18},"PoolArea":{"SideDoor":94,"ToiletDooroutside":29},
               "MainStairs":{"LightL":264,"TempL":260,"MotionL":259},"MasterBedroom":{"TempK":244,"MotionK":243,"LightK":248},
               "iOS":{"iPhone7":304,"iPad2":288,"iPhone":67,"iPadAir":17},"HomeOffice":{"SparePower(Gen5)":25,"SpareVoltage":39,"SparePower":65},
               "MediaRoom":{"MediaServer":20,"TVSwitch":5,"TVVoltage":40,"Integra":21},"Unallocated":{"Jeff":35,"128.0.2":305},
               "DiningArea":{"TempG":225,"LightG":229,"StandardLamp":294,"MotionG":224},
               "LivingArea":{"XmasPower":300,"FrontDoor":87,"AeonLuxA":193,"FrontEntranceTemp":88,"AeonTempA":192,"PioneerAVR":306,"AeonUVA":195,"AeonPowerA":131,"LivingAreaTemp":92, "LivingRoomTV":22,"SideDoorTemp":96,"XmasVoltage":299,"AeonHumidityA":194,"LivingRoomHTPC":23,"ReadingLamp":298,"SonosConnect":24,"LGTV":295, "AeonMotionA":191,"TableLamp":129},
               "Laundry":{"DryerPower":292,"ExhaustPower":64,"LaundryExhaust":62,"DryerVoltage":291,"TumbleDryer":290,"ExhaustVoltage":63},
               "Landing":{"MotionH":236,"TempH":237,"LightH":241}}
Edited by codowd
Formatting code block
Link to post
It looks like there is something wrong with the formating that may be related to the spacing you added.
I dropped you string into a json pretify site that makes it a bit more readable and it didn't recognise it as json)
I'll take a closer look...
one moment..
Link to post
I was thinking the same and you could try and remove them but I don't think that's the issue as they are enclosed in quotes.
Was this generated using ReneNL code ?
EDIT - just saw you thought you solved it
Did removing the quote solve the problem ?
Edited by AutoFrank
Link to post
I wonder, is it possible to create a function in a json table? In theory you could put a function you use in more then 1 place in the json. Then read it out, just don't know how to make a function based on that. You cant just say "function jT.function.something" perhaps you can with (), but you would want the have the name and the function in the json.
Link to post
I can confirm that the code in the first post will not work if the name of any device or room contains an apostrophe (') even though it encloses the apostrophe in quotes (").  You can see this if you just type the following line into the HC2 LUA editor:
local jT = '{"Boy's Room"}'
The syntax colour changes after the second apostrophe, indicating the quote finishes there, understandably.  This line is correct LUA:
jT = '{"Boy\'s Room"}'
So each string needs to be searched and replaced for apostrophes. The function required is
string.gsub(s, pattern, replace)
The following line changes will work (just replace the single string.gsubs with the nested versions
roomname=string.gsub(string.gsub(fibaro:getRoomName(roomID), "%s+", ""), "'", "")
deviceName=string.gsub(string.gsub(fibaro:getName(i), "%s+", "") , "'", "")
Edited by codowd
Link to post
