Guest ErnstH
Thanks. This doesn't seem to be the issue, but it made me think about the references.
I excluded the references one by one and I found that it is the erroneous referral to my own phone, which is named iErnst.
How should I refer to that? Obviously jT.iErnst is wrong....
(still don't understand how the line number is so different)
Guest ErnstH
Sorry, of course, that should be jT.iOS.iErnst
Then another questions about referencing the HomeTable.
In the definitions statement at the start of a scene, is it possible to refer to the hometabel too?
For example:
local jT = json.decode(fibaro:getGlobalValue("HomeTable"))
%% autostart
%% properties
120 value
%% events
%% globals
Instead of 120 I would like to refer to jT.kitchen.window.
But replacing 120 with that doesn't work, starting with local jT = ... doesn't help either.
Any suggestions?
For example:
%% autostart
%% properties
120 value
%% events
%% globals
Any suggestions?
Hi @ErnstH,
It is not possible to replace device ID's in scene header with HomeTable references. In scene header you have to keep ID numbers of the triggering devices and yes, you will have to edit header of all scenes that uses ID of device that changed its ID due to hard reconfiguration or exclusion/inclusion process.
    HI @ErnstH
    Sorry for the late reply
    The hometable references need to be exact and ARE case sensitive. It has zero flexibility.
    I have seen an Error referenced at line 334 that is really an issue like the one above
    Sometimes the exception notification for the HC2 is sometimes a bit off a doesn't always flag the correct line.
    Line 74 in a scene almost always points to an issue with a global; variable (empty, nill or does not exist)
    I have also seen Errors referencing getselfId in a scene that is flagging a syntax error
    There is a post here that talks to his -
    • 1 month later...
    Hello
    Have once again a question.
    I know the what I have shown below did not work, but how can I read the value from the json list.
    How can I sit down please can give me an example?
    Many Thanks.
    Edited by parip69
    • 2 months later...
    hi @AutoFrank,
    thanks for another awesome tutorial!
    I started playing around with it today. Everything works as expected.
    I wanted a more readable output of the HomeTable in the Debug window.
    So I found a LUA script in the internet and adapted it for Fibaro Debug.
    For this screenshot I used a simple nested hometable:
    I have a standard function to write to the debug window which i use in every scene:
    The function for the output of the HomeTable in JSON Format is:
    To output the Json you can now use:
    maybe someone finds this usefull as well.
    keep up the goood work.
    kro
    Edited by kroeatschge
    • 2 months later...
    Hi all,
    on the weekend I found some time and worked through the tut, and everything is really working great from the beginning.
    However, I found one thing that I could not figure out. There are iOS devices missing in my Table, but I do not have a clue why?
    I checked
     and all my devices are listed there...
    Hints?
    Cheers
    joystick
    Edited by Joystick
    • 3 months later...
    not sure if this is mentioned elsewhere, so just in case.... there is no need to manually add scenes and users, as suggested in the script on page 1.
    - Scenes can be added automatically with this snippet:
    - There is actually a type for users. Just add this to the main for-do-block:
    Cheers,
    jayrock
    • 1 month later...
    " to "
    Temat został przeniesiony z "
    " do "
    this code create and complete HomeTable variable if not exit or update it if exit, adding all users, scenes, devices, VD and iOS.
    • 5 weeks later...
    I'm getting the following error when running the below test Scene to to display some values extracted from my Home Table:
    /monthly_2018_05/image.png.ab3b0c68de439fd624b4ad5757167e93.png" alt="image.png.ab3b0c68de439fd624b4ad5757167e93.png" />
    Herewith the data from my Home Table:
    I'm clearly missing something, but cannot find the problem. Any suggestions?
    Thank you,
    @nicopretYou have spelt user name differently  or with a capital or user does not exist in system.
    Scene can't find jT.users.resia in HomeTable
    Edited by Jamie mccrostie
    Spelling and case is correct and user is in HomeTable. See debug output which pints contents of entire HomeTable. Below the relevant section.
    Herewith the top section of my HomeTable:
    I get the same problem for all users and also the scenes
    Edited by nicopret
    Ive had those errors before and they were caused by a typo.
    Try
    instead of:
      local user = fibaro:getValue(jT.users.resia, "value")
    Thank you @
     that solved it. The same format should be used for Scenes, Users, iOS and VD, i.e. basically anything other than physical devices. Below a small test scene that helped me to test that I retrieve the correct values from my HomeTable
    Edited by nicopret
    • 2 months later...
    hi,
    i read this topic more then 3 hours tried every code here ...
    can anyone please post final version of this code ( with sence, user....)
    also can anyone post a code for plot - if i want to see the table and everything in it
    thanks a lot of your help
    • 1 month later...
    hi all,
    I am using Homtable for some time now and its working as it should except one thing:
    I have never managed to get the iOS devices working in my code. When I try to reference my device with "jT.iOS.MyDeviceName" I always get the error "
    [DEBUG] 12:18:18: [1;31m2018-09-23 12:18:18.002027 [ fatal] Unknown exception: /opt/fibaro/FibaroSceneAPI.lua:115: attempt to concatenate local 'deviceId' (a nil value)
    However, the device shows correctly in the log etc...
    The spelling is correct, I also tried to change the "special characters"  code in the HomeTable code, however I always get this.
    Can someone help me here?
    cheers
    • 1 month later...
    Guest andyhud
    Great tutorial @AutoFrankand others.. so many different versions reading through all 6 pages! :)
    I have it working, basic, but working but couple of questions on the Scene itself
    1. It has "%% autostart" at the top, so should the Scene be set to "Manual" in the General Tab?
    2. Should the number of Max. Running Instances be set to 1 or leave on Default as 2?
    3. How often should the Table be generated in people's opinion? I was thinking to add the Scene to be scheduled by @Sankotronic's Scene for Time Based Events to run once a day (say 2:00am each morning)
    4. Could you somehow take the output in "Pretty Json" format and have it emailed to you each time it ran, maybe by @AutoFrank's Smart Message Hub 1.2?
    Cheers
    Andy
    Edited by andyhud
    Hi @andyhud ,
    1. Scene should be set to "Automatic"
    2. Default setting for instances is OK
    3. Table should be generated only if some changes where made with devices (added, deleted or reconfigured), best time is after reboot.
    4. That is possible to achieve, but why you need that?
