    4 minutes ago, FredrikKarlsson said:
    Another small note which relate to international characters in device and scene names.
    For sure, you can remove them all, but the names will then be a bit hard to remember. I prefer a solution like this for example:
    Of course the 'replacementTab' needs to be populated with what is appropriate for the language. The above example is what I use for Swedish.
    I prefer using "Rorelsetvattstugan" rather than "Rrelsetvttstugan" which I will never get right.
    Thanks @FredrikKarlsson
    It looks like lots of people have switched to using HomeTable solutions...
    Guest FredrikKarlsson
    Yes, I have certainly seen the light. Many thanks to you for making this tutorial available.
    I could also share a function I use for loading the HomeTable. Loading is not to complicated, but I often don't bother with all the checks in a scene if I set it up from scratch.
    Maybe it may be of use to someone out there.
    • T.Konopka featured this topic
    • 3 weeks later...
    I have added function for replacing the diacritic in devices and rooms.
    You can also add some other special characters via changing variable Diacritic.
    It could be helpful for some users ...
    Edited by petr23
    thanks @petr23
    • 4 weeks later...
    How do I check if the scene I created is creating the home table please?
    When I run a device that references the table, I press button and I get an error.  Debug is showing
    [ERROR] 16:42:43: line getGlobalValu..."]:2
    Any ideas what I'm doing wrong please?
    Hi @CelticWebs
    Could you post the hometable scene and the code you are using to reference the table ?
    Just now, AutoFrank said:
    Hi @CelticWebs
    I used your code for the HomeTable
    In the VD I was starting off simple.
    I also created a single Pre Defined variable called HomeTable with one item in it called Value 1
    I'm probably missing something stupidly obvious!
    @CelticWebs
    I actually create my table manually as I wanted a bit more control over the structure
    As a result I am not 100% of the structure of the table that is created (can you see after you run the scene that the table was created
    The table reference is probably incorrect (I see VD in your table creation and vd in your reference but it would be useful to see the whole table
    Try the following in a blank scene, it will print out the Home Table that was created.
    @CelticWebs
    Two issues here I think
    You need to match the case exactly so the VD should be upper case, you had lower case in your code above
    I also think that the hyphens are creating an issue in the call
    Try this in a blank scene
    and then try this
    what you should see is in the code
    If this is correct then you need to either remove the - in the device name or I think if you uncomment the following in your table creation it should remove your non-alphanumeric chars
    BTW - when you reply to the post if you put @AutoFrank in the post I'll see that you have replied... :-)
    Hi @AutoFrank you are correct that it's something to do with the hyphen.  Though uncommenting that code doesn't fix it because the hyphens are in the rooms not the devices.  Can I get it to remove the hyphens from rooms as well?
    @AutoFrank I just realised it was already in the code!  I've just removed the hyphens from room names as well and the scene we tried earlier is working now.
    @CelticWebs
    I'm not sure as I didn't write that code :-(
    What about if you replaced the hyphens in the room names with an underscore
    I think that will work with the home table reference
    If you replaced them with spaces then the hometable creation will just remove them and you could solve it that way
    personally I have something like Living Room in my HC2 but LivingRoom in my home table and this is what I reference and is easy to remember. If you go with option 2 above you'll can use that approach...
    @AutoFrank it was already in the code Frank :)  it strips hyphens out of the room names now :)
    I'm just working on the virtual device again now.  Now I have to work out how to get it to do something based on the result of an url, url will show a page with a 1 or a 0 on it and I need it to do something different depending on what the result is!
    Getting there slowly but it's a bit of a learning curve!
    @CelticWebs, glad you got it working.. for the url query, it might be good to start a new post and add a bit more content if you need help and that way other users can chime in based on the topic heading..
    @AutoFrank Going to have a go myself first and hopefully get that sorted without having to bother people.  I am intending on keeping a record of stuff I learn as I go that I can't find directly on the forum and later I'll put it up for others to find, if I'm looking for something, chances are somebody else is too.  Just like you posting the garage VD for me :)
    @CelticWebs
    I think that's a great strategy and other forum users will appreciate it. It's also the way I learned and I've managed to contribute a bit back as well. I have found that if a user is willing to have a go and make an effort they will gets lot of help
    Good luck with it and no doubt our paths will cross again :D
    _f
    I also have a "HomeTable" type of structure for (all) my scene configuration data. Here are two tricks that I have found useful.
    Assume you read in the table the standard way
    then one can make a "reverse lookup table" for the deviceID data because typically there are no  two identical deviceIDs. Care have to be taken if you have numerical data in the structure that are identical. Then only apply it to the branch with the deviceID data.
    Callling reverseMapDefs(jT) once after reading in the json data allows you later in the code, for debugging purposes, efficiently find the "name" of a deviceID.
    Ex. assume we have jT.house.bedroom.lamp == 56. In my code I have wrappers for many fibaro functions so
    will print in the debug window
    which says me more than 56...
    The other trick, a little tricker and not always applicable, is that my scenes that depends on the data automatically restarts when the global "HomeTable" variable changes. In principle they could just read in the data and try to reconfigure but usually so many pieces of the scene depends on the data so that is difficult. So in my case, the scene that constructs /configures the "HomeTable" has an additional functionality. First the scenes that depends on the data has the following code. (I'm coding this in my "event model" but it shouldn't be difficult to understand and translate to standard lua scene code...)
    The Event:remote is just a Fibaro:startScene(id, data) where the id is the id of my "HomeTable" configuration scene and the data is a message to restart the scene. In this particular case we check if the part of the "HomeTable" that we depend on has changed (dev.places) and not the whole structure. If it has changed we ask the configuration scene to start us up and then we terminate the scene (fibaro:abort()).
    The Configuration scene when receiving the message just looks at the return address (that Event:remote conveniently puts in the message) and waits a second or two and issues a Fibaro:startScene(message._from) that restarts the scene.
    I have a scene that gets away with just re-reading the data and not having to restart but in general I found it to be pretty convenient when updating the data to have scenes restart and reconfigure themselves.
    USING HOMETABLE TO STORE ICON ID's
    I had a couple of recovery events and lost my custom icons. I also started to use dynamic icons for my VD so I can use the icon to display state. This would be Garage Open/Garage Closed.
    As a result, i'm going to expand out my HomeTable to also cover icons so I can have a hometable reference in my code and if I loose or what to change an icon I can just update the hometable
    I added an extra entry to my hometable
    so the code above becomes
    I manually create my hometable but perhaps some user that dynamically creates their table may be able to provide code to include icon references
    -_f
    • 4 weeks later...
    Guest ErnstH
    Hi, new question (or I overlooked a previous one),
    I installed the HomeTable which in general works fine (tanks!).
    However, when replacing device ID's by hometable references I sometimes get messages like this:
    [DEBUG] 17:21:45: line 334: attempt to concatenate local 'deviceID' (a nil value)
    There ar only less than 50 lines in the scene, so I suppose it is refererring to another scene. But it's not in the HomeTable, which has no 334 lines either.
    How do I find out where this bug arises from?
    Or what do I do wrong?
    Not 100% if it's the same issue for you but thats usually the error I get when I type in the wrong reference to a HomeTable ID.  usually from a capital letter or something similar.
