MS6 including as ID 0 or not including correctly
hi,
I bought a bunch of MS6 devices
Some included okay and some are proving a challenge
I've noticed that some half include (ie I might get temp and motion but no humidity)
I also noticed that some are including as ID 0
I tried different power supplies, different cables, close to the HC2 and not so close
I tried the factory reset (hold include button down for 20 seconds)
I just trying to figure out if I missed something or just got a bad batch
Edited by AutoFrank
Just an update. I gave up running them on battery and now run the three MS6 that I have on USB power. On USB power they are nice devices and seem reliable. I would not recommend anyone trying to use them on battery.
I have also tested the sensor(Version 1.8) in my bathroom with batteries. My test ends 3 weeks later with empty batteries (expensive test 12 €). The sensor loses 3 times the connection and I have ghost device with ID0 in my HC2. Can someone explain me how I can delete it? I have another ghost device that I can't delete:
/monthly_2017_12/image.png.c753bd5911e06c182d1cda7674ad9647.png" />image.png.281561ed06819b242d92bce52f248f5c.png
Because it has no room name I can't delete it.
Edit: Ok this has nothing to do with Aeon sensor it's from my fibaro thermostat.
My conclusion is it's unusable with batteries so I think this is the reason why it's sold without them.
Edited by FunkFib
try to click on [X] on ghost dev (with show all mode on)
and on a question, "ORLY?!" say "Yes!" another case write to support
Thank you for your help.
If I delete the device like in your description I have no access and its fobidden for me:  ;(
