After I put together the Virtual devices Introduction Tutorial I was asked would I do something similar for Scenes.
I’ll preface this post (like the Virtual devices) that I am no expert but I am willing to document what I understand and it can be added to over time. It would be great if some of the experst could read through, fill in the coupelof gaps and let me know if I havesomething wrong or coudl do with better explanation
I also start at a very basic level as some of the newer users people liked that with the virtual device tutorial
I am also only going to Lua scenes as I have never worked with Magic Scenes or Graphics Blocks
Scene Basics
A scene is a mechanism to execute a lua code script for an on-demand basis.
General Tab
  • Name, Room - self explanatory
  • ID – set when the scene is saved, doesn’t change for life of scene. This is the unique identifier for this scene and can be used as part of the startScene command
  • Max number of instances – A scene can be called from a number of different sources. This dictates how many instance of the scene can be running concurrently. This can also be set within the scene using lua. I’m not sure if these two settings are in conflict which one takes priority.
  • Lili commands – voice control for running/stopping scene using Lili who is the native HC2 personal assistant.
  • Run Scene
    • Automatic – it can be called from other scenes or run manually
    • Manual – it can be called from other scenes or run manually (unsure what the difference is between manual and automatic)
    • Disabled – scene cannot be run
  • Scene Hidden: Not visible in the Web UI (unless you select HC2 hidden devices)
  • Protect by Pin: Prompted for PIN CODE if scene is set to running
  • Do Not Alarm to Stop: ???
  • Change Icon – select a new icon to display alongside the scene (128x128 png transparent)
 Advanced Tab
  • Lua Window
  • The code in the lua window is the defaulst header for any scene and needs to be kept.
  • Debug window (debug output from scene code when it is run)
    • START – Start the script running
    • STOP – Stop the script running
    • CLEAR – Clear the debug window
Web UI View
1.    Title of scene
2.    Edit
3.    Delete (confirmation req)
4.    Icon
5.    Disable/enable
6.    Run/Stop scene
7.    Status – populated by fibaro:log command
/monthly_2017_02/58a5dca14d223_image1.PNG.78743c2f462000ef3155e456f173bf52.PNG" />
 Lua Scene Header
The header of a scene always contains some of all of the following. These are used to trigger the scene in a number of different way.
%%autostart – including this means that the scene will run when it is saved or when the HC2 restarts.
$$ properties – the user can add a device ID and parameter. Any change to this parameter will trigger/run the scene. The format is ID following by parameter.
In the example above if 1429 was a door sensor and value was the status parameter that changed (0 <-> 1) when the door opened than any status change would cause the scene to run. This has to be the device ID and cannot be a variable that represents the ID
%%events – ??
%%globals – the user can add the name of global variable (exactly and case sensitive). Any change to the value of the global variable will trigger/run the scene
An example would be
A scene can be setup to trigger from properties, events or global variables
The following code allows a different action depending on the trigger if this is what’s required.
In the example above the following happens
  • Scene triggered from property (1425 value) - it will execute function1()
  • Scene triggered from global variable(sleepState) - it will execute function2()
  • Scene triggered from an autostart - it will execute function3()
  • Scene triggered from any other valid method  - it will execute function4()
  • or else the scene will no start
Local Variable declaration
These are variables tha you intend to use within the scene. You can also use global variable but these do not need to be declared prior to usage
Many people put the local variable declaration at the start of the scene followed by the functions
Code Comments
Comments /explanations in the code are very useful as the allow you to explain what the code is doing to either yourself or others
You need to preface or encapsulated all comments to prevent them being executed at runtime.
Example of single line and multi-line comments are shown below
In general all scenes will have the following structure but over time most people develop your own style …
Lua command syntax is generally the same whether it is used in a scene or used in a virtual device (exceptions to this are http requests)
Some useful lua command
Some useful lua functions
ENCODING - replace a space in a string with another character, a + symbol in the example below
This function takes one parameter - s
so The Cat and the Mat will be changed to The+Cat+and+the+Mat
ROUNDIT
Rounds a number to a defined number of decimal places
This function takes one parameter - num (the number you want rounded) and idp (the number of decimal places)
so roundit(2.12348, 3) would result in 2.123
If there are any other useful functions that you feel would be of benefit to new users please let me know and I'll include them
Overall the best way to gain a greater understanding is to download the many scenes that are published to the forum and start to take them apart.
I hope this will be of benefit to some users and suggestions and corrections are always welcome
happy coding
-f
Edited by AutoFrank
Link to post
Very nice job @AutoFrank!!
A scene set to manual can be run from an other scene aswell, I do it this way with my CO2 alarm.
Once the admins approve it (since last sunday) you can see. Or if you want I can pm it to you
Jim
Link to post
Encoding
The best way to gain a greater understanding is to download the many scenes that are published to the forum and start to take them apart.
The one major difference in Fibaro’s interpretation of Lua between virtual devices and scenes is http  and tcp socket requests
The format to be used in a scene is as follows
REGULAR HTTP REQUEST
ENCODED HTTP REQUEST
TCP SOCKET CONNECTION
Perfect, thanks @AutoFrank
Great cheat sheet to go with VD tutorial
Understood everything, kind off, but the LUA  "useful function" bit  was a mystery
Cheers
Edited by Jamie mccrostie
Link to post
  • Thanks for the feedback @Jamie mccrostie
    I edited the first post with some additional detail to clarify some information
    I also removed the http request/api information as it wasnt a good fit for the topic and I will include that in an Introduction to api/HTTP requests tutorial I am putting together
    Edited by AutoFrank
    Link to post
    • T.Konopka featured this topic
    Very nice!
    Is there a possibilty to backup all scenes (incl. hidden scenes) with just one click ?
    (and the same questions for the VDs)
    Link to post
  • 25 minutes ago, Orgli said:
    Very nice!
    Hi @Orgli
    I believe the HC2Toolkit written @Krikroff can do that but I have never used it.
    I think you can download it from the french forum
    -f
    Link to post
    • 1 year later...
    " to "
    Temat został przeniesiony z "
    " do "
    Link to post
    • 1 month later...
    • 1 year later...
     How can I create a block scene which can only be run manually or from another scene? I.e not run by a trigger and not run upon start of the HC2?
    It seems I have to choose a trigger at the top of the block sequence. Not choosing a trigger generates a LUA code which generates errors because it creates an empty if statement.
    Link to post
