Please help! I need translations for HC supported languages and more!
Hello everyone!
Please help me to translate bellow words inside quotes in your languages. HC is supporting bellow languages and I need translations on all of them, but even on those languages that are not mentioned here (except Croatian, that I have already :) ):
HC supported languages:
Here is what I need translations for:
Thank you in advance for your help!!!
sleepstatemap is for home status if it is put in sleep state or awake.
presentstatemap is for home if everybody is away, or at home or on holidays (trip)
fixed_time_txt is if user selected that any part of the day will start at fixed time, so time will not follow sunrise and suset.
Edited by Sankotronic
Attachment quota filled up / deleting older stuff sorry :-(
    1 minute ago, Bodyart said:
    Hi @Sankotronic,
    don't you have grey hair yet? :-D
    Just few on beard, but after this project I'll became not grey but white since Angelina (HC2) likes to play games with me teasing me all the time with not refreshing pages forcing me to debug bug's that are hers and not mine :-P
    I'm glad, that i'm white already... you know women are women,,,
    Estonian translation takes much longer than expected, so if anyone else is faster, please go ahead.
    Sorry for not having better news
    kuno
    Edited by kunoch
    On 4/23/2017 at 11:29 AM, Sankotronic said:
    This is what is left:
    @Sankotronic,
    Do you still need Estonian translation ?
    kuno
    Hi @kunoch,
    No worries, it is not urgent and whenever it is done I can add to the Translation scene.
    Hi @gucio1234,
    I don't have Estonian yet as @kunoch still didn't get it. I have added Weather State and Netatmo VD, Icon preview VD and Philips HUE VD to the list that I also need to be translated to all mentioned languages. Here is the list:
    there is a restriction to the length of caption text to 15 characters. I left some on the list above to be longer just to make it clear what it is about, but in several of them I will have to shorten word "temperature" to "temp." to fit on button or label.
    Thank you for helping!
    @Sankotronic to add new and missing translations, it would be easier to find the new items, if all languages would be collected in a spreadsheet.
    Edited by kunoch
    @kunoch,
    if I understand you good it will be easier to have it in table format like Excel sheet with all translations? Ok, I can do that just give me some time because I need to see how to move all that data from LUA code to spreadsheet and back.
    Yes, correct, that would be easier to see the empty cells.
    Converting excel into code can be done using string commands and then copy paste into the source code editor.
    kuno
    Edited by kunoch
    @Sankotronic,
    Here is Polish translation (might need a little correction depending on context) :
          weatherstateVD      = {v_desc    = "Pogoda",
                                 temp      = "Temperatura",
                                 temp_hi   = "Temperatura MAX",
                                 temp_lo   = "Temperatura MIN",
                                temp_trend = "Temperatura TREND",
                                 humid     = "Wilgotność",
                                 humid_hi  = "Wilgotność MAX",
                                 humid_lo  = "Wilgoność MIN",
                                 press     = "Ciśnienie",
                                 press_hi  = "Ciśnienie MAX",
                                 press_lo  = "Ciśnienie MIN",
                               press_trend = "Ciśnienei TREND",
                                 noise     = "Poziom hałasu",
                                 co2       = "Poziom CO2",
                                 wind      = "Prędkość Wiatru",
                                 wind_dir  = "Kierunek Wiatru",
                                 wind_hi   = "Wiatr MAX",
                                 gust      = "Prędkość porywów",
                                 gust_dir  = "Kierunek porywów",
                                 gust_hi   = "Porywy MAX",
                                 rain      = "Deszcz",
                                 rain_hr   = "Przez godzinę",
                                 rain_3hr  = "Przez 3 godziny",
                                 rain_day  = "Przez dzień",
                                 rain_week = "Przez tydzień",
                                rain_month = "Przez miesiąc",
                                 light     = "Jasność",
                                 uv        = "Indeks UV",
                                 soil_temp = "Temperatura gleby",
                                soil_moist = "Wilgotność gleby",
                                 place     = "Miejsce",
                                 station   = "Stacja",
                                 n_module  = "Moduł",
                                 batt      = "Poziom baterii",
                                 signal    = "Poziom sygnału",
                                 update_ok = "VD uaktualnione",
                                 update_er = "Błąd aktualizacji"},
          iconpreviewVD       = {label1    = "Grupa ikon",
                                 label2    = "Ikona",
                                 label3    = "ID Ikony",
                                 label4    = "Naza Ikony",
                                 label5    = "Ilość Ikon/Suma",
                                 button61  = "Poprzednia Ikona",
                                 button62  = "Następna Ikona",
                                 button71  = "Pierwsza Ikona",
                                 button72  = "Ostatnia Ikona",
                                 label8    = "Wybór grupy ikon",
                                 button91  = "Ikony VD",
                                 button92  = "Ikony Scen",
                                 button10  = "Ikony Pokoi",
                                 label11   = "Ustaw Ikonę VD",
                                 label12   = "VD - ID",
                                 label13   = "VD - nazwa",
                                 label14   = "VD - pokój",
                                 label15   = "VD - numer ikony",
                                 label16   = "VD - ikona",
                                 label17   = "VD - opis ikony",
                                 button181 = "Poprzednie VD",
                                 button182 = "Następne VD",
                                 button20  = "Ustaw Ikonę VD"},
          hueVD               = {brightness = "Jasność",
                                 hue       = "Odcień",
                                saturation = "Nasycenie",
                                ct         = "Temperatura barwowa"},
          commonVD            = {on        = "Włącz",
                                 off       = "Wyłącz",
                                 yes       = "Tak",
                                 no        = "Nie",
                                 refresh   = "Odświerz",
                                 previous  = "Poprzedni",
                                 next      = "Następny"},
    Edited by gucio1234
    Hi @gucio1234,
    thanks for translation! You are fast! :-)
    I will make excel file with all needed translations and put it here so that it can be filled up as it goes!
    @Sankotronic,
    Estonian translation :
    et = {timeofdaymap        = {Morning   = " Hommik ",
                                 Day       = " Päev ",
                                 Evening   = " Õhtu ",
                                 Night     = " Öö "},
          seasonstatemap      = {Spring    = " Kevad ",
                                 Summer    = " Suvi ",
                                 Autumn    = " Sügis ",
                                 Winter    = " Talv "},
          weekdaymap          = {Sunday    = " Pühapäev ",
                                 Monday    = " Esmaspäev ",
                                 Tuesday   = " Teisipäev ",
                                 Wednesday = " Kolmapäev ",
                                 Thursday  = " Neljapäev ",
                                 Friday    = " Reede ",
                                 Saturday  = " Laupäev "},
          monthmap            = {January   = " Jaanuar ",
                                 February  = " Veebruar ",
                                 March     = " Märts ",
                                 April     = " Aprill ",
                                 May       = " Mai ",
                                 June      = " Juuni ",
                                 July      = " Juuli ",
                                 August    = " August ",
                                 September = " September ",
                                 October   = " Oktoober ",
                                 November  = " November ",
                                 December  = " Detsember "},
          sleepstatemap       = {Sleep     = " Magama / Magada ",  MA- and DA-infinitives
                                 Awake     = " Ärkama /Ärgata "},  MA- and DA-infinitives
          presentstatemap     = {Home      = " Kodu ",
                                 Away      = " Eemal ",
                                 Holiday   = " Puhkepäev / Vaba Päev, Puhkus, Vaheaeg  "},  depends on context
          demomodemap         = {On        = " Sees /Sisse  ", depends on context
                                 Off       = " Väljas / Välja  "}, depends on context
          fixed_time_txt      = " Kindel Aeg",
          sunriseVD           = {label1    = " Päikesetõus on…",
                                 label2    = " Aeg Hommikuni ",
                                 label3    = "  Hommik Algab ",
                                 label4    = " Aeg Päevani ",
                                 label5    = " Päev Algab   ",
                                 label6    = " Päikeseloojang on…",
                                 label7    = " Aeg Õhtuni",
                                 label8    = " Õhtu Algab ",
                                 label9    = " Aeg Ööni ",
                                 label10   = " Öö Algab "}
    Thank you @gucio1234, both translations added!
    sorry, but my Estonian colleague does not seem to provide the translation, but you have it already received, so it is no issue anymore
    Thank you @kunoch,
    I will prepare spreadsheet with translations when I will have all necessary text as you suggested and then it will be much easier to do all translations.
    If its possible it would be nice if Fibaro could do a Norwegian translation to. I`m happy to contribute if necessary.
    Hi @thomas.hvindenhaug,
    I will add Norwegian to my new system and will need your help to do translations. Will post documents here as soon as I prepare them.
