[email protected] 2
Hi There
I want to discuss a bout the new way of scene creation.
This is DIY. It comes from " Do It Yourself". By this, smarthome user can introduce a scene with out any knowledge of computer.
It would implement by 3 steps:
1- change the house appliances as the way you want ( like turn on the dimmer and fan, close the curtain and ...)
2- just click on save condition (save all the statuses of appliances)
3- Run the scene ( home will change as the save conditions like the statuses step 2)
However Fibaro has 3 kinds of adding scene, but DIY can be perform as the newest and easiest way of smarthome learning,
So, I want to make a scene to create panel for DIY in VirtualDevice like below:
code of SAVE Button:
local mystat = fibaro:getValue(135, "Value")
fibaro:debug(mystat)
fibaro:debug(tonumber(mystat))
code of RUN Button:
if (tonumber(mystat) == tonumber("0"))
then
fibaro:debug("off");
fibaro:call(135, "turnOff")
else
fibaro:debug("on");
fibaro:call(135, "turnOn")
But, it just save and does not work (RUN).
Would you please help me in this way ?
How to save statuses and the run them again ?
ADMIN NOTE:
Please, read carefully descriptions of forum before posting.
Edited by [email protected]Wrong forum.
