I like to start a scene at every keypress on my Zipato Mini Keypad with RFiD
Example:
Zipato Away + PIN >>> Start scene Arm
Zipato Home + TAG >>> Start scene DisArm
Zipato Away + TAG >>> Start scene Arm
Zipato Home + PIN >>> Start scene DisArm
This works fine, no problem so far but if i'm also using my smartphone it doesn't work
1) Yesterday Alarm Disarmed by Zipato-Home-key + PIN
2) Today Alarm Armed by Smartphone
3) Today i try to disarm by Zipato-Home-key + TAG >>> NO TRIGGER
Fibaro HC2 doesn't start a scene at step-3 because 'value' was not changed, for the system i pushed the home-key again (step 1 and 3)
How do i trigger a scene with FIBARO LUA every time a key was pushed?
Every key-press is send to Fibaro HC2 as it shows in the status screen
[23:11:56] ID 299: locked by user 2
[23:24:50] ID 299: unlocked by user 2
[23:24:58] ID 299: locked by user 2
[23:25:25] ID 299: locked by user 2
[23:25:43] ID 299: locked by user 2
[23:25:54] ID 299: unlocked by user 2
[23:27:46] ID 299: locked by user 2
[23:27:52] ID 299: locked by user 3
[23:27:57] ID 299: unlocked by user 2
[23:31:03] ID 299: locked by user 2
[23:31:13] ID 299: unlocked by user 2
[23:47:04] ID 299: locked by user 1
[23:47:11] ID 299: unlocked by user 1
SCENE HEADER:
%% properties
299 value
%% events
%% globals
Can somebody help?
Edited by xirilius
6 answers to this question
I'm almost in the same boat as you are except i wasn't able to transfer the pins from the controller to the keypad, can you please describe how did you do this? And also how did you trigger a scene when pressing home/away?
@xirilius
what i have done is create a scene for my alarm system which is triggered by variable changes, eg variable 'alarm' set to 'arm' or 'disarm'.
then i create a scene for the keypad which just changes these variables to either 'arm' or 'disarm'.
i also then created the 2 extra scenes for use on smartphones, 1 for 'arm' and 1 for 'disarm'.
this way i can use any combination to 'arm' or 'disarm' the alarm and which works perfectly fine.
cheers
2 minutes ago, morpheus75 said:
@xirilius
cheers
Can you tell me how you registed the pin codes? I don't know how to do this.
Thank you
@abpostelnicu
there was a thread on here which showed how to register the keyfobs and pin codes. on the hc2 about a year ago when i set it up at a clients house i couldnt name the tags or the PIN code but i used the following scene:
fibaro:call(ID,'setUserCodeDec','1','Occupied','143,40,28,11,1,32,2,128,0,0')
fibaro:call(ID,'setUserCodeDec','2','Occupied','143,24,148,18,1,32,2,128,0,0')
fibaro:call(ID,'setUserCode','3','Occupied','4321')
where ID is the RFID keypad.
if i remember correctly when you scan the tags the number appears in the window at the top of the browser
3 minutes ago, morpheus75 said:
@abpostelnicu
Excuse me but i own a HCL so i don't have access to native LUA code.
then im sorry i dont know.
