jakub.jezek 372
Hello guys,
I ran into interesting problem. Honestly i do not know if problem is in Fibaro or Global Cache, so i need some help. Ticket in partners dedicated channel: #95470.
I'm doing VD for a customer (Fibaro dealer) for control of Somfy RTS module (VD is below). But i'm able to receive only 8 comands, then it seems like connection get stucked. If i send commands from iTest (global cache app), that i am not a problem to receive more than 8 commands. If i send commands from Fibaro to PC directly (Hercules app can be set as TCP server), then i'm able receive more than 8 commands (Same port and protocol, just diffrent IP adress).
I'm sending those serial commands (RS-232/RS-485) to my Laptop to application Hercules (Link below).
Global Cache i'm using is iTach Flex IP. Cables connected are Flex Link RS-232 cable and Flex Link RS-485 cable. I tested it with both.
As RS-485 to USB converter i'm using something like that:
or this one (rs-232)Please login or register to see this link.
@T.Konopka or @M.Baranowski, can you look at this one please?
Global Cache Cables:
Hercules app link:
Virtual device:
13 answers to this question
