adham 0
Hi ,
I am using both HC2 and HCL in master slave mode. and i tried to activate alarm panel to take actions in arm mode.
first, i selected emergency lights , close blinds and send notification and tested it and it worked good. this situation was before adding any other scenes to the system. i activated the alarm panel in the HC2 (master controller) only .
After adding several scenes ( Ex: scenes to open and close lights according to motion detection and LUX in several areas ) , i tried to re test the alarm panel by arming the motion sensors in my system and try to breach any of them.
when i did so in the 1st trail only the blinds closed but no notifications sent and the emergency lights did not work as well. i tried to reset the alarm panel and deactivate all actions and re enable it again. when i did so nothing of actions took place.
Hint : i have several scenes take place several rimes and always there is notification to alarm that that scenes run sequently more than the number of runs i set in each scene ( 10 times )
my question : is this delay due to these scenes which run a lot or this is a bug in system ?
i am using the latest update in both controlled ( not the beta one )
