Scene not doing anything
can anyone see why this simple block scene doesn't seem to function on Qubino DC shutter?  (see attached).  It should lower or raise to 50% if temperature between 16 -18 degrees.   I have separate scenes to raise above 18 and lower below 16 which appear to work ok (The module is actually connected to my greenhouse door!).  The LUA converts to this:
%% properties
149 value
%% globals
if (
 ( tonumber(fibaro:getValue(149, "value")) > 16 )
and
 ( tonumber(fibaro:getValue(149, "value")) < 18 )
or
then
 setTimeout(function()
  end, 100000)
  Thanks.
Link to post
%% properties
149 value
%% globals
if (
and
or
then
  end, 100000)
  Thanks.
Hi @15green
I don't work with block scenes buy two things stand out for me ...
1) if you want the action to execute with 16, 17 and 18 then it should be >= and <= instead of > and <
2) I can't see any reference to the action (lower/raise to 50%) that is to take place when the temp is between 16 and 18
Edited by AutoFrank
Link to post
Hi AutoFrank
1) I take your point with the <= thanks.
2) Me neither and I don't know what the timeout 1000 part is either. Do we assume the block scene is not converting correctly... Is this a known problem?
Link to post
Hi @15green,
First of all, converting block scenes to LUA was always a bit tricky. However, please check whether the block scene works now (after @AutoFrank suggestions).
I've created a sample block scene, similar you yours, to check the block scene to LUA conversion:
and the code is much simpler:
%% properties
56 value
%% weather
%% events
%% globals
if (
 ( tonumber(fibaro:getValue(56, "value")) >= 16 )
and
 ( tonumber(fibaro:getValue(56, "value")) <= 18 )
or
then
	fibaro:call(34, "setSlider", "15", "50");
Could you tell us what version of firmware do you have, maybe it's an issue which has been resolved.
Link to post
Hi there (I don't know how to insert user link!)
My scene now looks like this but still fails to operate, I notice yours has another value (15) after the call function that mine does not?  My HC2 runs 4.056.  Thanks.
%% autostart
%% properties
149 value
%% globals
if (
 ( tonumber(fibaro:getValue(149, "value")) >= 16 )
and
 ( tonumber(fibaro:getValue(149, "value")) <= 18 )
or
then
 fibaro:call(166, "setvalue", "50");
Link to post
Okay,
So in that case, please back up your HC and upgrade it to 4.130 and do this scene again, completely from scratch.
Link to post
If you do not have Satel devices, upgrade should not break anything.
Edited by I.Srodka
Link to post
Here is at least part of your instruction, why and when do the reboot:
Quote
Before firmware upgrade with same reason, to make upgrade to clean system
Edited by I.Srodka
Link to post
Hi All
Can I not perform update from my remote location?  I have done backup & restart but after accepting upgrade terms I get "access denied" to start upgrade.
Link to post
I have backed up, restarted, run ok for a few hours, and started upgrade.  Now I cannot connect just get rotating dots.  Been over 1hr, how long should an upgrade take?
Update- back on after clearing browser cache.   Have re-made scene in block mode which appears to work ok.  Thanks @I.Srodka
Edited by 15green
Update
Link to post
