can anyone see why this simple block scene doesn't seem to function on Qubino DC shutter?  (see attached).  It should lower or raise to 50% if temperature between 16 -18 degrees.   I have separate scenes to raise above 18 and lower below 16 which appear to work ok (The module is actually connected to my greenhouse door!).  The LUA converts to this:
%% properties
149 value
%% globals
if (
 ( tonumber(fibaro:getValue(149, "value")) > 16 )
and
 ( tonumber(fibaro:getValue(149, "value")) < 18 )
or
then
 setTimeout(function()
  end, 100000)
  Thanks.
I don't use block scenes but it would be great for somebody familiar with block scenes to wrote some "getting started" tutorials..
Any takers?
