15green 0
can anyone see why this simple block scene doesn't seem to function on Qubino DC shutter? (see attached). It should lower or raise to 50% if temperature between 16 -18 degrees. I have separate scenes to raise above 18 and lower below 16 which appear to work ok (The module is actually connected to my greenhouse door!). The LUA converts to this:
%% properties
149 value
%% globals
if (
( tonumber(fibaro:getValue(149, "value")) > 16 )
and
( tonumber(fibaro:getValue(149, "value")) < 18 )
or
then
setTimeout(function()
end, 100000)
Thanks.
21 answers to this question
