MaTi 29 Share Posted September 26, 2017 The Danalock 3 with Z-Wave support has been released. Before actually buying one, can someone please confirm compatibility with the HC2/HC-lite ? Thanks Quote Link to post Share on other sites
0 Soft 17 Share Posted October 3, 2017 Mine will arrive today, hopefully Quote Link to post Share on other sites
0 Soft 17 Share Posted October 5, 2017 I have installed it, working as a lock! One problem is that the Locked/unlocked signs under the icon is wrong, open is closed and vica-verca Anyone with a suggestion on this ? There are no parameters... Quote Link to post Share on other sites
0 jakub.jezek 265 Share Posted October 5, 2017 Just now, Soft said: I have installed it, working as a lock! One problem is that the Locked/unlocked signs under the icon is wrong, open is closed and vica-verca Anyone with a suggestion on this ? There are no parameters... Regarding parameters. it has no template, so you have to fill parameters (if default settings is not enough). How did you upload the icons? 1st is icon for closed state and 2nd icon for open state? If yes, did you tried to upload icons in reverse? Quote Link to post Share on other sites
0 Soft 17 Share Posted October 5, 2017 It's not the icons that are wrong, its the little lock/unlock underneath the icon Quote Link to post Share on other sites
0 jakub.jezek 265 Share Posted October 5, 2017 Hmmmm, in my case, i did not see reverse behavior. Quote Link to post Share on other sites
0 janton 2 Share Posted October 10, 2017 Hello. I have also this new Danalock V3 lock. I managed to get it included to HC2 through add doorlocks. I could not add a scene that gives email or push -message when the lock have been opened through Fibaro app. Have someone managed to get any scene working with this lock ? If yes...can I have help how to create a scene which are working. Quote Link to post Share on other sites
0 janton 2 Share Posted October 10, 2017 Actually...I managed to get Magic scene working with push and email messages. Graphic block scenes are not working... Quote Link to post Share on other sites
0 janton 2 Share Posted October 10, 2017 Are somebody so skilled and can do LUA-code for Danalock V3 with following rules: 1. Someone opens the door lock (id: 656) through iPhone fibaro app 2. Then Fibaro sends push and email messages to iPhone (id´s: 391 and 610) Help is really appreciated ! Quote Link to post Share on other sites
0 Soft 17 Share Posted October 10, 2017 I would like to have a block scene where the absence of iPhones in the devices list triggers a lock command:-) Dont understand why I can see the devices, when I can't use them in a block scene. Seems you can with LUA though. Quote Link to post Share on other sites
0 Teddan 3 Share Posted October 10, 2017 Have a Danalock V3-BTZE that i can´t add in HC2, i have version 4.140 any known issues? Have tried both "add lock" and "add device" (security mode) but it won´t add. Help please! Quote Link to post Share on other sites
0 Soft 17 Share Posted October 10, 2017 (edited) @Teddan Did you press ONE time into the tiny hole on top of the lock to set it into learning mode?. the lock should have a green light when in that mode. I have 4.120 @janton I have a scene that lock the lock everyday @22.30 Edited October 10, 2017 by Soft Quote Link to post Share on other sites
0 Teddan 3 Share Posted October 10, 2017 No, i activated z-wave search mode in app, maybe i`ll try your way instead. Quote Link to post Share on other sites
0 Soft 17 Share Posted October 10, 2017 The app is not working for this, in general I think the app is crap! Quote Link to post Share on other sites
0 Teddan 3 Share Posted October 10, 2017 It worked, thank you for quick support! Quote Link to post Share on other sites
0 Soft 17 Share Posted October 10, 2017 Always happy to help a fellow Scandinavian 1 Quote Link to post Share on other sites
0 sonnyboy 11 Share Posted October 11, 2017 I got my Danalock V3 yesterday and the inclusion went smooth, had to be about 3 meters from my HC:2 during the inclusion. Then i mounted it on my door and the device went dead, did a neighbor update on Zwave on this device and then it worked fine. The lock has very very high sound when it locks and unlock Now i just want to have in the lock in a scene but that doesent sems to go? i i trie to do a block scene and click on my lock nothing happens Is there anybody that have the correct lua to lock and unlock this device? Or maby a complete snippet to put in GEA Quote Link to post Share on other sites
0 Soft 17 Share Posted October 11, 2017 --[[ %% autostart %% properties %% weather %% events %% globals NoenHjemme --]] local startSource = fibaro:getSourceTrigger(); if ( ( tonumber(fibaro:getGlobalValue("NooneHome")) == tonumber("0") ) or startSource["type"] == "other" ) then fibaro:call(137, "secure"); end Quote Link to post Share on other sites
0 sonnyboy 11 Share Posted October 11, 2017 @Soft Thanks for the snippet Will test it tonight when im home again. It will go in to GEA like this, and hopefully it will work. GEA.add(true, 30, "Ytterdörren är nu låst", {{"Time", "22:00", "22:01"}, {"secure", Hallen["DoorLock"]}}) The door will lock at 22:00 and a push to my phone with "Ytterdörren är nu låst" Quote Link to post Share on other sites
0 Hugger 0 Share Posted October 13, 2017 Do you have some experience with the danalock V3 in combination with the Fibaro Intercom (in the app)? It seems to be impossible to open the door with the 'Open' button. The doorlock does not appear in the list of devices: Output to open the gate. Quote Link to post Share on other sites
0 Soft 17 Share Posted October 14, 2017 I never understood the intercom thingy! Is it a separate app, and how is it integrated to HC2 ? Quote Link to post Share on other sites
MaTi 29
Link to post
12
9
6
Oct 2
14
Oct 10
10
Oct 24
7
Oct 25
6
Soft 28 posts
jakub.jezek 12 posts
petervanderpol 9 posts
Teddan 6 posts
Oct 2 2017
Oct 10 2017
Oct 24 2017
Oct 25 2017
jakub.jezek
@MaTi, We have bought one for tests directly from Poly-Control (guys responsible for Danalock). I will start testing it in few days.
Sankotronic
Just my little contribution, maybe you will like it: Enjoy!
jakub.jezek
Hi @MaTi and othere following this topic. So i have tested it and it is working. And i think you will hear sound of locking/unlocking Danalock from the other side of the door. Is pretty lo
89 answers to this question
