Good evening everybody,
I am new to the Home Center 2. Before today I used a Raspi 3 with "Home Assistant" and I have quite a few z-wave devices, like the Fibaro Roller Shutter 2, Fibaro Motion Sensor and so on. Since the whole "Home Assistant" thing did not work out 100% with all z-wave devices (problems with Sensative Strips binary mode, Motion Sensor, z-wave USB stick crashes) and it is also pretty uncomfortable to configure, I decided to go the Fibaro Home Center 2 way.
Since I am pretty impatient I ordered the Home Center 2 from Amazon prime-now same day and just got it delivered.
After unpacking and connecting to the router I receive a "503 error - server unavailable". I rebooted everything and still the same.
Things I tried:
- empty caches, using different browsers and computers
- recovery - even it should be on factory settings anyway
- disconnect a couple of minutes from power
- reboot Fritz!Box (using a 7590)
I spent now 3 hours and  I still have not seen any login screen. Very frustrating!
Oh yes, the leds: the right 3 ones are on, the "update available" is blinking.
Any ideas from someone beside sending it back to amazon?
Regards, any help appreciated,
Marc
Edited by marc1112
typo
6 answers to this question
Just a thought. Is the Fibaro HC2 an European or an American version? Have you bought it from Amazon.org or .de?
    I bought it from Amazon.de, so I guess its the european version (as it should be).
    OK. So it is not that!
    It is working now.
    I just let it sit. It seems that the system was performing an automatic update before first login. But I read nothing about anything like this in the documentation. It always said: power up the system and after 2 minutes login and then perform an update. Strange. Or just bad documentation.
    Anyway, I am just updating now to the actual version and hopefully be able to add the first devices soon.
    Thanks anyway :).
    So I’m having this same issue. Brand new out of the box. Powered it up. Three LED lights are on but I still get error 503.
    --EDITED For anyone else with this issue. It took about 2.5 hours for the controller to do its thing after first powerup.
    Edited by al98t
    I had this problem recently as well. There was nothing in the documentation to suggest it would be attempting an update so I spent half a day trying different browsers, rebooting, etc and came to the conclusion the unit must be faulty.
    Eventually I walked away to do something else and returned a couple of hours later to be presented with the login screen.
