Americo 0
I have a Samsung SmartThings Hub Sth-eth-200 and a pair of Fibaro wall plugs FGWPE/F-102 ZW5.
I had not problems adding the plugs to the network. They are detected and I can see the power consumption and the state (on/off). However, if i try to change the state (on/off) remotely it doens't work.
The only way to switch on/off is manually pressing the push button on the plug. So it´s kind of useless.
Is this normal? Is there any way to fix this?
Américo
4 answers to this question
