Circuit setup FGD-212 same as FGD-211 possible?
I found a circuit setup that exactly matches my wiring needs. It is meant for FGD-211. Can this setup also be used
for FGD-212. You can find the picture below and also following this link:
In my understanding fgd-211's  output terminal "O" corresponds to the output terminal of fgd-212.
best,
ypoosn
7 answers to this question
Hi @ypoosn!
Welcome to our community!
The scheme above may work but it is not so safe to do that.
I will advise you to follow our wiring diagrams:
    29 minutes ago, I.Srodka said:
    Hi @ypoosn!
    thanks for your answer.
    "May work" -> 'OK, I will try, eventually it will blow up the dimmer ;-)
    "not so safe" to do that -> what do you mean by this?
    - from an electrical point of view? All used switches an cables are designed for 240V and 16A currents.
    - from the technical fibaro dimmer perspective?  Because the circuits are not designed to handle Load an Sx?
    best,
    ypoosn
    Hi @ypoosn!
    Connecting Dimmer in a incorrect way will void your warranty.
    The L-pin is secured in a special way. Joining Sx to it is not the best way to do it.
    It doesn't matter that your cables are rated 16A when Dimmer is not ; )
    I will suggest once again that you should follow the diagram provided by us.
    Okay.
    My problem is that I have to use the existing wiring somehow (see below)
    best,
    ypoosn
    Hi @ypoosn!
    It is indeed a problem.
    You can place another cable between those switches for Dimmer 2 to be fully operational.
    Alternatively you can a relay with coil for 230V. This relay should be placed between Sx and S1.
    Okay, thanks for your hints and support.
    Probably I found another solution. Its a zwave dimmer module that allows direct wiring of switch input pins to L
    best,
    ypoosn
    I'm having more or less the exact same issue.
    And I have already bought two FGD-212's, so if this does not work then that was a fair share of wasted money..
    Am I understanding this correctly, in that the S-pins are not using 230V? That it's some other low voltage control signal only?
    In my case I have a switch box in my living room with numerous switches in it. These switches controls the various ceiling lights.
    Inside these boxes there are really not room for anything more, so I have to put the dimmer out in the ceiling box.
    Out there what I have is three wires; L + N,  and a switched wire that connects to L when on.
    So the module linked by @ypoosn would be perfect, but as I say, I already bought the fibaro dimmers...
    Any suggestions?
