mabu 0
I am having a problem with the inclusion of my Dimmer 2 module (FGD-212 v3.5 ) into the Z-Wave>Me system, using a Razberry module (unfortunately, I don't use the Fibaro HC). Everytime I try to include the Dimmer, I get the error message "Inclusion takes a long time to start up.".
I tried several inclusion menus:
After activating the inclusion process in the Z-Wave interface, a red LED is flashing on the Razberry module. I then pressed the B-Button three times (within approximately 1 sec.). I also tried to include the dimmer using the switch.
Unfortunately, none of the above described methods worked. I also did a reset on the dimmer - but it didn't change anything in the inclusion process.
Both devices use the "EU-frequency".
Any suggestions what can cause the inclusion problem?!
