I have some strange issues with custom device images. When i put custom images devices, VD buttons, etc. there is a difference between images in web based acces to my HC2 compared to the images in the IOS app. On the IOS app I see images I did use in the past. Eevery time when I perform a backup recovery, the problem turns back.
If I then import a lot of new images, delete them again (this will increase the images ID number) untill I reach a fresh image name, than the images between web based access and mobile app are in sync. So I did find myself a workarround :-) However each time I do a recovery, the effort to reach a fresh image range will be more time consuming.
It seems to me that when I upload a new image, the  system will make a copy of the image for use in the mobile app. When I delete the image, the web based image will be gone, but the mobile app copy is not deleted and will not be overwritten once an new image is imported in the web interface. This would explain the mis match.
Is this a known problem? Is there a way to solve this. As my Fibaro environment is increasing in size, the change that I make a LUA  mistake that requires a backup restore is increasing.
Help or sugestions to adress this issue is highly appreciated.
Kind regards,
Menno
Edited by Langedijk
  • 1 month later...
