  • 2
BUG: Impossible to change house location
I can't change the location of my house. The problem looks like a bug in the system.
At first, I couldn't find the possibility to change the location at all, as the Longitude and Latitude information appear like static labels on the Configuration->Location page. Then, after using Safari browser, I found a hidden button (please see screenshot #1). But, after clicking this button, I was redirected to the page with the broken map (please see screenshot #2). I stuck on this page as no matter what I do, the location doesn't change.
- If this is a bug, how to notify HC2 developers so they could probably release a fix in next firmware version?
- If it's not a bug, how to overcome this problem?
Hi Fabir,
Thanks for the tip and I am also using Firefox and I just clicked on a different timezone then clicked back on my timezone and clicked save. Then moved the pin to my actual street address and bingo it all worked.
Thanks again for your assistance.
Best regards
Beeker
Guest rallen
I too am running 4.543 and cannot change my location.   I want to set up gps so when I come home the garage door raises, outdoor lights turn on and the garage entry door unlocks.   I could do this with my other HA controller.
Did you do the Time Zone first?
This is getting to be the worst system ever.
I have tried the swagger API. Times out or returns garbage.
Tried using postman to send the API json I can get but not send it just seems to lock the thing up every time I send. No result. Tried Post and Put commands.
Tried moving the pin around and redoing the wizard over and over again. Still  nothing.
Event tried it all after a reset. I can run the get location API fine.
All this on top of once it synced with the Fibaro Dimmer in my lounge there is no dimming action. Why did the competitor manage the dimmer better than this? Basically set to go back to my old competitors product rather than this HC2.
Any ideas would be appreciated from everyone.
Seems to me the next option is go back to the competition and buy their newest device after returning this. If you know people are having a problem, maybe change the UI. Like let people enter the lat/long manually in the GUI?
Postman:
Get Command 200OK
Put Command - Always 503 service unavailable.
Swagger UI:
Get Command OK
Put Command: 0 - No Content
Firmware:
4.570
Event resorted to putting back what I get from the get command with the same results:
    "houseNumber": 18,
    "timezone": "Australia/Sydney",
    "timezoneOffset": 39600,
    "ntp": true,
    "ntpServer": "pool.ntp.org",
    "date": {
        "day": 1,
        "month": 2,
        "year": 2020
    "time": {
        "hour": 9,
        "minute": 52
    "latitude": 52.25,
    "longitude": 16.53,
    "city": "Poznan",
    "temperatureUnit": "C",
    "windUnit": "km/h",
    "timeFormat": 24,
    "dateFormat": "dd.mm.yy",
    "decimalMark": "."
What happens when you using localization panel?
