is there a way to make home or away Variables by using your wifi at home so the Fibaro system nows when I ip dress comes into the area it know someone is home
you can simply use API call:
http://192.168.1.36:80/api/networkDiscovery/arp
for getting all devices in network. But it sometimes ugly and works not properly.
also, you can simply search some scripts in this forum.
otherwise if you developer you can use my work :)
so, I wrote a script and call it every 5 mins
notice: I created in HC global vars for each family member.
in HC LUA script I check if all members are 0 and send to device push popup notification with asking to arm house.
also, I have VD.
    can't see you vd to showing up
    can I copy you Lua code but just change the ip address and Mac address and will it work
    yep
    /monthly_2018_04/image.png.a6c2b5c488308437ed4ff22bcade7ba4.png" />
    btw. it's python. not LUA.
    python code works on my raspberry pi server.
    Edited by 10der
    what do you mean by python code works on my raspberry pi server.
    omg. did you see my note here?
    sorry. I can't.
    I use two solutions based on what fits best for the user/phone i want to track.
    Presence detection via Wifi:
    and
    Presence detection via IFTT:
    To translate the pages I use Google Chrome browser.
    Enjoy.
    Remi
    1 hour ago, Remi said:
    as I can see
    1) phones should have static IP
    2) idk, what is a port pinging. this port closes for my IPhone. AFAIR 3500 it's RTMP Port. but again idk what mean the author of this post
    your second link also useless for me. :)
    native FIBARO integration works with periodically requests (polling) user GPS location. It's not a good solution as for me for this task:
    1) not accurate at all
    2) require "GPS always on"
    3) as a result -  FIBARO app ("eat") drain battery
    4) and last - main issue (as for me) - real IP address and your ISP must not use NAT firewalling for your router.
    Iam sorry if none of the solutions fit you well. I am sure there will be a lot more solution to achief the same.
    For the first solution.
    None of my phones has a static ip and its working like a charm. (Maybe i am just lucky to get the same IP every time :) )
    Your correct about the iPhone (I don't have a IPhone) but If I remember correct they had a solution/workaround for that.
    You have to read further in that topic I gues. (sorry)
    For me, as I am using android its working very good.
    As for the second link, you didn't read the whole article.
    They use the Fibaro solution as intro, in the second part of the page they explain the better solution I am using.
    Isnt a free DDNS registration a solution you can use for changing outside IP?
    I am using the first solution for my kids.
    Its often they have burned their MB's of their mobile subscription and without internet access solution 2 doesn't work :-)
    Also having a low battery has impact since it put (most) phones in a power save mode.
    So i use the first solution for my kids. When they get in range of the wifi they are registered "Home" and vice versa.
    For me and my wife i use the second solution.
    I like that better since the trigger to register me home is much sooner while the first solution has a delay of ~1 minute.
    In rare occasion's the second solution mis the trigger, but overall both solution work very well for me.
    Edited by Remi
    " to "
    Temat został przeniesiony z "
    " do "
    ISP NAT firewalling mean what all (sic!) ports in your router are closed via your ISP
    trick with DDNS doesn’t work, Sir
    just FYI
    Edited by 10der
    Sorry, didn't know that! Thanks for explaining sir :)
    19 hours ago, 10der said:
    as I can see
    @10der As this Vfib has been created by some smart guy on the French Fibaro forum and my LUA knowledge is limited (I can make simple scripts :) )
    How I think it works. You doesn't need a fixed IP for a phone. It doesn't need to know your IP at all.
    It does a scan (Ping) over the network and look in his own ARP cache if it find the MAC address of your phone.
    Maybe you have seen version 1.0 on the first page? (I think version 1.0 used a fixed IP indeed)
    Latest version is 2.1
    Vfib 2.1:
    Create global variable, for example your name with value's "Home" and "Away".
    Fill in MAC address in IP field of VD (Must be lowercase)
    You have to customize some things in the VD to your own.
    Like the icon's ID's and change the global variable name and value's to the one's you created.
    But your a lot smarter than me with LUA so maybe needless to explain this all :)
    thank for the answer. will do.
    but looking via ARP cache - it's bad. really bad. IMHO plus own experience
    btw
    local HC2 = Net.FHttp("127.0.0.1", 11111);
    you can simple replace
    Edited by 10der
    @10der I trust you about that, but iam wondering whats the bad thing about that?
    Is it the "overhead" of scanning the whole subnet while searching for only one device?
    It seems to work very well for months now.
    20 minutes ago, 10der said:
    btw
    api(/networkDiscovery/arp)
    Is this the same but different notation, or better?
    Thanks,
    Remi
    also.
    is too long operation and costly operation for HC2 - if you have 4 family users you should call this operation 4 times.
    or
     so. look like a complete solution for you:
    1) create globals params
    2) define the name in the script without suffix "Presence"
    3) create global param AutoPresence
    profit!
    Edited by 10der
    @10der ROFL Sir! I am truly speechless! Awesome!
    You made this this morning? Amazing.
    I like the idea to have one script instead of 4 or 5 (in my case)
    And I love the VD layout with status and counter for family members.
    Would you be so kind to share the Vfib with me/us ? :)
    Edited by Remi
    Thank U /bow  :)
