is there a way to make home or away Variables by using your wifi at home so the Fibaro system nows when I ip dress comes into the area it know someone is home
On 4/18/2018 at 11:29 AM, 10der said:
Line 67 gave an error. I have read this thread Like 15 times but can’t get it working. Just bought my hc2 and have alot to learn. Anybody over here who can help me understand this Lua code better?
thanx in advance
@boegia Ok here is latest VD
please play attantion what VD works with pre-defined vars!
please create this vars before.
1) SecuritySystem with string values:
AwayArmed / NightArmed / Disarmed
2) AutoPresence just as normal  integer var
3) family global vars (integer) according Name and VD labels
Name + Present
for example
/monthly_2019_10/image.png.c4f28de02978889157d3c899da2d99f7.png" />
VD config done
if you have
 otherwise skip this!!!
UniFi_checker.lua  - presence checker by UniFi WiFi
please change this accordin your settiongs
done
Wifi-presence.LUA  - simple (native) wifi presence checker
just configure macs and Names
done
Nobody' Checker
Name + Present
for example
VD config done
if you have
done
done
Do you need a cloud key for the unifi checker? or just the controller and AP?
please do no overquote in order to ask one question :
I have a local controller. in local network
@10der Ok thanks, I will implement this and try it. What do I need to fill in at "local site"?
The site name at (Settings > site > site name )or Controller name (Settings > Controller > Controller Name)
Because I get this:
[DEBUG] 13:49:24: Connection refused
[DEBUG] 13:49:29: Connection refused
[DEBUG] 13:49:34: Connection refused
[DEBUG] 13:49:39: Connection refused
I'm sure I filled in the right IP and user/pw. Because I can login with those credentials to the controller.
Edited by pnutp0wer
@pnutp0wer
it's what after http:// in your browser
On 10/28/2019 at 9:23 PM, 10der said:
local unifiController = "192.168.1.29:38193"; local site = "e29bk95t"; local username = "unifi"; local password = "unifi";
hi @10der i don’t mean the controller, I mean the second line in the above quote.
got it
ok!
/monthly_2019_10/image.png.0676e40783ed6d80db749718e2c00170.png" />
Thank you!!
Ok, mine is "default" according to my IP:
But when I enter this I still get in the debug "Connection refused".
localhost?
lol
for HC2 localhost is gray box with caption "Home center 2" :)
But how did you install UNIFI contrloller on HC2? :)
so. my guess your controller on your work PC.
and your work PC has IP address,
this IP address different from IP address of Hc2
and finally you should
run
ipconfig (if you on Windows)
ifconfig / ip address (if you on *Nix or mac)
and catch your IP address
so,. put this address as controller address
Edited by 10der
and one notice here.
Hc2 should / must have access for this controler on your PC
what i mean? IP PORT from ypur PC should / must be accessable from local network and HC2 as well
Edited by 10der
Ok yes, I had to fill in the IP address of the computer which runs my controller.
Now I'm running into a different issue. After I added the variables, I implement the LUA script and than the VD.
When I save the VD, the users are shown with their status. But after a few minutes all users turn into "X".
Even when they're still connected to the WiFi. A disconnect and reconnect doesn't help. I also installed the variables and the script again, but neither is working.
Furthermore, I don't get any line or error in the debug window..
Edited by pnutp0wer
can u uncomment
in
function checkPresence(tbl)
print(dump(tbl))
@10der
It's working! I just had to wait a little more. In your latest LUA scene there were some additional lines which need to be uncommented too.
Thank you so much! Maybe you can share it in the Downloads section?!
Edited by pnutp0wer
IT WORKS!
1 hour ago, pnutp0wer said:
Downloads section?!
not sure if it is useful :)
Yes I think it's very useful, especially for some scenes where you might want to split up GEOfencing and presence based on wifi connection.
GEOfencing is not always working on the right time so wifi connection could be an answer or maybe a backup functionality
@10der Thank you for sharing this great VD with scenes. But I have one issue, first my wife is marked as absent and after she is present I'm absent. Every time I start the WiFi presence scene it changes back, I'm present and my wifi is marked as absent.
Debug Wifi presense scene:
/monthly_2019_11/63951380_Schermafbeelding2019-11-26om00_13_45.png.f79b6b1237f1e31be5e5d2bfc93e6592.png" />
Debug VD:
@kevin if you asking about mode with internal fibaro API
 - it's question is not for me.
you can run
this endpoint manually and try to find you and wife mac here.
if not - :(
but as I can remeber grabbing local network via ARPinging it's give  not 100% succ result.
Edited by 10der
