is there a way to make home or away Variables by using your wifi at home so the Fibaro system nows when I ip dress comes into the area it know someone is home
Share this post
Link to post
Thanks @10der for this
I hope you don't mind but I made 2 minor changes to your Unifi_Checker.lua to enable this code to check for the Unifi Devices (USG, AP) instead of the Clients
The LAN Checker VD didn't work to check if the AP is offline as there are no open ports
Within the function getDevices(cookie)
Change
to
Within the function has_mac(tab, val)
Change
to
I also tweaked the text to show as being offline/online as opposed to being present
/monthly_2020_01/image.png.2db7a4ac1e0c35907504eeca02aba77a.png" />
I suppose the changes to check both the Unifi devices and clients could be incorporated into one scene
anyway, I hope this helps someone
Edited by AutoFrank
Share this post
Link to post
@10der thanks for the scenes and VD, this was exactly what I was looking for.
I have a Unifi Cloudkey Gen2 Plus on my network, so implemented your Presence state VD and Unifi checker scene. Followed your instructions for setting up the Global variables.
I'm seeing some strange behaviour: when I switch off Wifi on my iphone I can see the Unifi checker debug change from "Presence yes: MyName" to "Presence no: MyName", but after a couple of scene loops it changes back to "Presence yes: MyName".
Any ideas what might be wrong?
Thanks,
Share this post
Link to post
Quote
You can turn on debugging
and we can look what happened
Share this post
Link to post
This is a cut and paste of the debug from the unifi checker scene:
/monthly_2020_01/image.png.588deb608ac84dc059ebf66f23790366.png" />
Turned of my wifi at 21:52:50 and kept it off, 45 secs later the scene turns presence on again (while in my Unifi dashboard I am not present). The time between re-appearance seems random, sometimes 10-15 sec, sometimes longer, sometime it will not set presence to "no".
Thanks,
Edited by 6Blok
Share this post
Link to post
I would like to ask for advice:
- "Unifi checker" cannot be used because I do not have a HW controller and therefore I do not have a controller IP address but only an address that starts with "localhost ..."
- so I wanted to use "wifi-presence", everything is set up according to the instructions, but continuous detection of MAC presence on WIFI. Do I still have to start the scene?
- last I installed "presence-state", which should evaluate the status of "wifi-presence", but also misrepresenting, because "wifi-presence" seems not to run periodically for initial detection.
Where am I making mistake?
Share this post
Link to post
