The new version of the Multireg/HeatIt z-wave thermostat for electrical heating has now been released, it seems, see
 Here it says "available Q2/2018" but the Z-TRM2 product has recently been included in the supplier's catalog.
The new
Thermofloor (in Norwegian), indicates that integration with Fibaro Home Center 2 has been tested, including templates etc. Looks promising!
If anyone installs this device and includes it in a Fibaro system, please share your experience here!
    This thread may have become a little long. I started with the non-availability of the Z-TRM a year ago. Now we are discussing problems with configuration and operation of installed units. Anyway, here is another contribution. I was a bit confused by the way parameters may be set both through the thermostat display panel and as z-wave parameters. My best interpretation of the way this works, is summarized in the table below. ThermoFloor tells me that there will be a template for the HC2 "soon", but Fibaro is not known for speedy implementation of 3rd party templates. For now we have to add parameters manually, to check that my numbering is correct. I have not tried this in practice yet, the below table is a desk-top exercise.
    /monthly_2019_03/image.png.206e55becd158e5f34e73c8370b6275f.png" alt="image.png.206e55becd158e5f34e73c8370b6275f.png" />
    The text is in Norwegian, but should be self explanatory, I think, if you consult the user instructions for the thermostats as well. The column "Ønsket" is my preferred setting.
