Mellquist 0
Dear Forum-gurus,
I´ll try to explain this as briefly as possible. It might not even be such a big problem, but i just can´t seem to find a solution by myself.
Heres the explanation of what I want to do:
At our cabin/vacation home, we would like to be able to control the temperature with two different modes; Home and Away.
The salesman who put us up to the idea of Fibaro, suggested the Wall Plug as a unit to control the on/off power of the Heating Panels in the different rooms and use the Temperature Sensor built in to the Smoke Sensor to trigger different scenes depending on the temperature.
Now;
I am able to tell the Wall Plugs to activate and turn on the heating panel if the temperature of a room gets below say 20°C and turn off again if the temperature reaches say 23°C - by using scenes.
What i don´t seem to be able to is to make a "MASTER" scene to activate all the different scenes within the cabin. This means that per wall plug and temperature sensor, i need two different scenes for the low and high temperature - as well as two different set of scenes depending on which mode i need to activate (I.e: Home or Away). This means that i´m left with quite a lot of scenes to trigger on or off.
I guess my question is if theres any possibility of making a "MASTER" scene that triggers a defined number of scenes to turn on or off - and that way make both a Home and an Away mode?
I´ve tried looking into the "Heating Panel", but it doesn´t seem like it´s compatible with the Wall Plugs.
The system i use is the FHC Lite.
Please let me know if theres any relevant info i´ve left. Kind of hard to put this into words.
Edited by Mellquist8 answers to this question
