tubaad 0
I have added a new HCL as a slave in a Master gateway (HC2).
Issues:
- Rooms are not being synced in either direction
- Some of the master devices show up in the HCL slave, but unconfigured, with no names and with rooms not assigned
- List of shared devices are empty
Both gateways are running 4.520
Have tried the following:
- Master (HC2): Under Config>Gateway Connections I have Imported multiple times. Slave rooms show up, are checked, but after a quick Sync the are not added to room list.
- Master (HC2): Under Config>Gateway Connections I have Synced multiple times - no effect what so ever
- Master (HC2): Under Config>Gateway Connections I have Deleted the slave (HCL) and re-added. No luck
- Rebooted both devices twice. No luck
I would be very happy for any advice.
Device list on slave:
Link to post
