Hi, here is the guide how to flash custom recovery image for the HCL 4.140-4.150
Custom recovery allows to flash unsigned firmware in your HCL. This way we can add some new features or fix annoying bugs fast.
First of all, I want to say, the solution is 2 years old already. The security issue allows to execute any code on the HCL side. I have reported to Fibaro support about the vulnerability allowing to have complete contol of HCL device, but they answered its user's problem :)
We need to get root access in order to flash custom recovery, but HCL's ssh server disabled password login. So we will use the root exploit to restart ssh daemon with user:password login. Then we can use ssh to complete the process.
Rooting
Reboot the HCL before any manipulations, because low free RAM may prevent running the ssh daemon after killing.
We will use the Python 3 for exploit, but you can prepare the request with any convenient way. Edit hcl_4140_root.py script with your credentials and run it.
Writing recovery image
Use any ssh client (like putty) to login yout HCL using username root and password hc2
Copy the custom recovery image hcl_cr_v10.img to /tmp folder using ssh then run:
Quote
# dd bs=1M if=/tmp/hcl_cr_v10.img of=/dev/mtdblock8
Done! Now you can reboot recovery and enjoy the unsigned flashing.
All manipulations is at your own risk.
hcl_4140_root.py
hcl_cr_v10.img
  • Thanks 5
Link to post
  • 6 months later...
  • Replies 80
  • Created
  • Last Reply
Top Posters In This Topic
Hi, here is the guide how to flash custom recovery image for the HCL 4.140-4.150   Custom recovery allows to flash unsigned firmware in your HCL. This way we can add some new features or fix
BTW, good news for HC2 owners: HC2 NewOS recovery already has "signature ignore" mode and we can use stock recovery to flash custom firmwares. To enable it, need to create a file "/mnt/nvm/i
HomeKitten v1.7 changelog: Room bridge added. Every room is now separate bridge accessory. Device naming changed because we adding one room same time, so no more mess with names. Max bridges (ro
how you implemented fibaro rooms support? cuz dy default homekit all device assigned to single room
Link to post
homekit rooms have nothing to do with fibaro rooms
u can manage rooms from Home app, but manually for every accessory
Groping devices by rooms required to bypass homekit limit to 100 accessories per pridge
Link to post
Added support for actors and sensors
Weather sensors and thermostats will do later
Today is the test run day on the HCL device (before was running on x86 pc)
I hope all will be ok
Link to post
HCL 4.560 with HomeKit support built-in
Probably, it will not support all of your devices, but its a good start ;0
Setup code for the bridge acessory:
Enjoy it
Edited by jack.daniels
Reuploaded the image
Link to post
Some details:
-instant events polling. once your device changes state it will report to the home app immediately (not once in X seconds)
-low battery warning for battery powered sensors (under 20% hardcoded)
-weather providers support (home app will see temperature and humidity)
-real voice control is now covers your fibaro hcl controller
-lightweight service binary ~300kb still leave enough ram to run HCL in usual way including LUA environment
-zero configuration time, it just works after power on
-after adding new devices you need to re-add the bridge accessory in home app, so best practice will be to connect homekit in the last turn
Link to post
Can you see how much is the size of the partition of users can save data?
i think if it could reserve some space to do swap...
I’m not a Linux expert... 😆
Link to post
Yes, but swap is disabled in kernel, so its useless to resize partitions etc
Link to post
Small update is ready. Homekitten v1.3
-Tamper status reporting in Home app
-Room devices grouping is now enabled automatic, only when devices>100
-Device name in format: "<name> - <room_name>" for non-grouped mode (easier to sort out the mass of items)
-Memory leak fixed
Still problem adding attachments here, so here is the link
  • Thanks 2
Link to post
