Another stupid question :)
Can we solder out the HCL Z-wave board and connect it to another device like RPI4 or others?
On 6/6/2020 at 11:24 AM, jack.daniels said:
Current HCL controller is running on ZW 300 series chip.And the firmware is available for this chip only
Remote controls seem to be skipped by the bridge, is this normal? How can we use them via MQTT?
Nov  5 17:02:38 HCL-078863 HomeKitten[774]: SKIP: [id:28 / room:219] keyfob_1 = com.fibaro.FGKF601 / com.fibaro.remoteSceneController
Nov  5 17:02:38 HCL-078863 HomeKitten[774]: SKIP: [id:36 / room:219] wallmote_1 = com.fibaro.remoteController / com.fibaro.actor
Nov  5 17:02:38 HCL-078863 HomeKitten[774]: SKIP: [id:42 / room:219] zrc_1 = com.fibaro.remoteController / com.fibaro.actor
Thanks!
Answering myself: after loading homekitten in IDA, it appears that some devices are simply skipped by the bridge, so not "all devices" are supported. In particular, all remote controllers are ignored. Patching the binary to allow for example the Fibaro keyfob allows it to register, although the MQTT events reported on button press are rather dumb (but usable nevertheless):
/fibaro/fibaro/connected 1
/event/28/icon { "path": "fibaro\/icons\/com.fibaro.FGKF601\/com.fibaro.FGKF601-1Pressed.png", "source": "HC" }
/event/28/icon { "path": "fibaro\/icons\/com.fibaro.FGKF601\/com.fibaro.FGKF601-default.png", "source": "HC" }
/event/28/icon { "path": "fibaro\/icons\/com.fibaro.FGKF601\/com.fibaro.FGKF601-2Pressed.png", "source": "HC" }
/event/28/icon { "path": "fibaro\/icons\/com.fibaro.FGKF601\/com.fibaro.FGKF601-5Pressed.png", "source": "HC" }
Any reason for this behavior?
OP, can you please enable remotes to be bridged to MQTT?
Thanks!
    HCL 4.600 with HomeKitten 1.8.5
    iOS14 No answer fixed
    Enjoy it
    Ill take a look. I have Fibaro KeyFob
    Many devices still not supported, as I dont have them here to test (like locks, RGBs,roller shutters) - this is a field for the future work.
    HCL 4.600 + HomeKitten 1.8.6
    • Memory leak on poll events in 1.8.5 removed
    • AVAHI single thread to advertise all the bridges (before was a thread for every bridge)
    • Thanks 2
    • 1 month later...
    HCL 4.600 + HomeKitten 1.8.7
    • Critical socket OOM issue fixed
    Merry Christmass
    • Like 3
    @jack.daniels
    Hi ! New around here and just run into this topic.
    A couple of days back I bought a used HCL from eBay. I come from domoticz and decided to test hcl to see if covers my needs since my automation is basically zwave and a couple of ds18b20....
    I updated hcl to latest version 4.600 and then find out that with your image I can use lua too.
    So my question is, can I use your .py file from post 1 for custom recovery etc. And then run HCL 4.600 + HomeKitten 1.8.7 ?
    What are the steps to follow since I am on official 4.600 ?
    With HCL 4.600 + HomeKitten 1.8.7 can i have a local backup or only cloud ? FIBARO id and remote access works ?
    Regards
    Bill
    Hi, Jack )
    I'm use hcl_4600_lua_homekitten_187, it works good !
    I have a question ?
    Can lua be used in virtual devices on HCL?
    I figured it out !!!
    Just a sort quide for nobs like me.
    Press win key +x to open command prompt
    if success then
    finaly ssh with putty and
     If someone use this change ip and path to file with yours...........
    Great job
    On 1/3/2021 at 8:55 PM, BurnerMan said:
    @jack.daniels
    Regards
    Bill
    on my side it was mandatory to downgrade to previous version 4.520
    Of course I downgraded first...Now I have setup my system and everything works ok.
    Cause I'm new in HCL, when will come time to update let's say to version 4.610, what I do? I just push the update through recovery from repair from file option ? My devices and scenes will remain there ?
    Edited by BurnerMan
    @jack.danielsis the debug function works for you ?
    if i try a simple
    fibaro:debug('Hello world!') nothing appears in my console when i ran the scene  ?
    did i miss something ?
    @jack.daniels Since we already use lua, can you support import LUA virtual devices ?
    if i try a simple
    In new os (4.500+) they removed the debug messages output, probably to save RAM
    I was tried it but no success
    I am trying to keep the thread up, so just check it for the latst releases.
    Hi, everybody. I can't cope with the problem after I entered another value in the variables panel, all the data was lost . The system does not allow you to enter manually because there are more values in the name than you can enter !
    Hi, which variable u mean?
    if its one of HomeKitten settings, you may delete it and reboot. Default value will be created
    Thank you for your quick response ! These names were spelled out:
    HK_MQTT_OPT_CONTROL_PAYLOAD
    HK_MQTT_OPT_CONTROL_TOPIC
    HK_MQTT_OPT_EVENT_PAYLOAD
    HK_MQTT_OPT_EVENT_TOPIC
    And if it is not difficult for you, you can ask to paint the basics of some mqtt settings in HCL. I do not understand why RGB Driver does not get anywhere as a device. Thank you very much !
    Carefully read everything understood by rgb tapes !
    Edited by Banknotame
