Has anyone been able to intergrate a hue kit like a virtual device into a hcl? I have tried to follow the instructions in this forum but not been able to control the hue hub from the virtual device button.
Anyone? ?
I recently updated the Hue Virtual Device for HCL (Home Center Lite).
You need to replace [HUE_HUB_LOCAL_IP] with the local IP number of your Hue Hub (
You need to replace [HUE_USER_ID] with your Hue Hub User ID (
You need to replace [LIGHT_ID] with your Light ID that you want to control (Starts from 1 and goes on as much as the numbers of lights that you have connected to your hue hub)
You need to create different virtual devices for each light.
Now you will be able to use the action of Hue Virtual Devices that you created in block scenes.
Best,
Kaan
Edited by Kaan
