Showing results for tags 'virtual deice'.
Found 4 results
  1. Hi dear Fibaro people. Anyone know how I can create a button in the app (for HC3) that I can use to enable or disable a scene? (A recipe would have been brilliant )
  2. hi, i need to send this command "https://IP/api/callAction?deviceID=136&name=pressButton&arg1=1" to HC3 but the answer is "Class does not have pressButton function defined - action ignored". To do this I created a quick app of the type "remote controller" but i think is not the same as a "virtual device" https://forum.fibaro.com/topic/12399-beta-api-http-commands-3341/page/5/ so I would like to know how to create a virtual device who responds to the action call. thanks
  3. Hello everybody here, I'm new on this forum and I have an issue with my virtul device created on HCL. In particular, after have been created a virtual device with a button and a label, I would like to assign an action for a such button. Let's say, I want to turn on some phiscal device and update a label's value to "Turned On" respectively. By using a String option on HCL, I managed to send a single SOAP request(on a button click) in order to either turn on device or change label's value separately. The issue is that, I would like to execute both things togather. In the following I'll share my code which I've tried to assign to the button: Case 1 GET /api/callAction?deviceId=131&name=turnOn HTTP/1.1 Host: 192.168.1.31 Authorization: Basic Base64_encode_of(login:password) Case 1 Works fine Case 2 GET /api/callAction?deviceId=113&name=setProperty&arg1=ui.Label1.value&arg2=Turned%20On HTTP/1.1 Host: 192.168.1.31 Authorization: Basic Base64_encode_of(login:password) Case 2 Works fine Case 3 GET /api/callAction?deviceId=131&name=turnOn HTTP/1.1 Host: 192.168.1.31 Authorization: Basic Base64_encode_of(login:password) GET /api/callAction?deviceId=113&name=setProperty&arg1=ui.Label1.value&arg2=Chiuso HTTP/1.1 Host: 192.168.1.31 Authorization: Basic Base64_encode_of(login:password) Case 3, both things together, No. It executes only the first request. So I've been wondering, is it even possible to carry out something like case 3? And if so, where I've been failing? Thanks for any kind of help!
  4. Has anyone been able to intergrate a hue kit like a virtual device into a hcl? I have tried to follow the instructions in this forum but not been able to control the hue hub from the virtual device button. Anyone? ?
