    @jgab
    /monthly_2020_08/image.png.6f70a2dcac70d1bed85102279793ad87.png" />
    I have another question for you @
    Can you please give me an example of query for Grafana, with this new scene ? I tried the following, but it says « no data »... (the data source is working correctly)
    Edited by 10der
    It’s working perfectly. Now I have my data in Grafana !
    Thanks a lot for your help :-)
    Edited by jguellec
    u r welcome!
    Thanks to you @10der, I’m starting to have a nice dashboard in Grafana ?
    I have (again ?) a quick question for you ! In this function :
    saveToInflux(measurement_name, value, deviceID, deviceName, roomName, sectionName)
    Let’s say I want to display a Grafana Panel with the Fibaro software version (ex.: 5.040.37). I noticed that it wasn’t possible to have a String in « value ». Only numbers. Is this an Influxdb limitation ?
    Have a great end of day !
    AFAIR yes, but let me check... maybe tomorow.
    PS: cool dashboard. realy cool!
    Take your time, no rush ?
    Thanks for the dashboard, wouldn't have been possible without your support !
    • 2 months later...
    Thanks, works perfect with HC3!
    Hc3 should work without python
    at all
    search by forum my script
    • 1 month later...
    Thanks a lot @10der for sharing all your insights.
    Congratulations @jguellecfor creating this fantastic Grafana DB to visualize the Fibaro HC data. Is there a chance you would share the dashboard here
     ? I would love to use yours as a template to configure mine - once I managed to get the scene @10der shared to deliver the data (but I am working on this now).
    • 3 weeks later...
    Hi @10der! Thanks for the guidance! I have a question, I just started studying, so there are a lot of questions :), but first. Grafana does not see the Influx database. What could be the mistake?
    Thanks @Nick_Clever. I’ve been away for few weeks, haven’t seen your message before, sorry.
    I’ve shared the dashboard on grafana :
    And I also attach the .json file here, if anyone’s interested.
    I made some updates, but feel free to use it.
    • Thanks 3
    • 1 month later...
    Today I thought I would install Influxdb and Grafana to develop good looking dashboard like in this post.
    I tried to install Influxdb on my Synology NAS with Docker. Docker and I are not so good friends. Instructions are always a bit different with my Docker and it always works a bit different or not. In this case "not". Some frustration and removed the containers.
    Is for example Influx on a Raspberry Pi a more stable option? Anyone an advice?
    Edited by SmartHomeEddy
    Hi @SmartHomeEddy,
    I have no experience with influxdb on a Raspberry but what is the problem with docker on the NAS ? I personally have influxdb installed in a docker container on my Synology and it's very stable.
    If it can help, I used this image with default settings :
    Good luck
    Edited by jguellec
    I used the official InfluxDB docker image. But the instruction didn't exactly match the real thing. As soon as I started the terminal, there were errors. Couldn't create anything, no users, no databases. etc. Bummer, it looked like it was doable. I will give i a seconds try this weekend with your link.
    Ok, let me know. You don't have a lot of things to configure. Just install the image, create the DB for the HC3 datas, and you're done. Then you just configure a datasource in Grafana and that's it.
    @SmartHomeEddy
    Here's an excellent guide to getting started with Influx and Grafana on a Raspberry Pi.
    Thanks, yes it looks doable. Didn't got to Grafana, installed it but needed to get further with InfluxDB. But what could go wrong :-)
    If it can work stable on Synology / Docker, then that is the easy route. But if for example a Raspberry Pi gives more stability, no problem, I switch to Raspberry Pi.
    Will give it a second try on Docker, otherwise the Raspberry Pi will be the next route.
    (Then have to order the Raspberry Pi, I see a RaspberryPi 4 Model B should be OK, @RH_Dreambox any advise on the amount of internal memory?)
