    2 hours ago, KaWi said:
    Hello @10der
    Are you still on a bus trip? ?
    In the meantime, I tried to create the code myself. Unfortunately, I failed.
    no HC2.
    HC3 "naked" only QA's + some bored ZWave devices what i can't replace via ZigBee.
    but, about influx... yes. but right now I have re-writes this module.
    • 1 year later...
    All, I have installed 10der‘s script and configured the access credentials. However, when I run the script, debug shows „401 unauthorized“ . Any idea what could be the problem? I can access the influxdb 2 with the credentials from the script via the web interface. I’ve read that installing influxdb 1 might be a solution … but what has to be changed for influxdb 2? Thanks! Cheers Alfons
    SOLVED: Installed influxdb v1 - now it works!
    Edited by awlieser
    • 2 months later...
    Witam, jest jakiś sposób aby odczytać log a nie stan? odczytując stan tracę informacje np. o czujkach ruchu, które pomiędzy odczytami zdążyły zmienić swój stan.
