Quote
@RH_Dreambox any advise on the amount of internal memory?
I first started with a "Pi 3 Model B +" (1 Gb) and it worked perfectly well.
But then I wanted to try a Pi 4 that is a bit faster and then it became a "Pi 4 Model B / 4GB"
It looks very nice @10der!
I like to try this also with my HC3 but I am stucked.
On Pi 3B
I cant create user/data base
<create database home
use home
create user grafana with password 'XXXXX' with all privileges
grant all privileges on home to grafana
show users
user admin
grafana true>
Give me an error:
command not found
Any idea or help for this noob?
Thanks in advance
//Sjakie
@Sjakie
You may have missed typing the "influx" command required to create and edit the database.
pi@raspberrypi:~ $ influx
Connected to
version 1.8.3
InfluxDB shell version: 1.8.3
  • 3 weeks later...
I gave up on Docker. Got my Raspberry Pi today and got InfluxDB and Grafana running.
I followed this instruction to get the Raspberry Pi started with InfluxDB and Grafana:
Also installed @10der script.
And it is running!
Now finding out how Grafana really works, get some values in and work on a fine dashboard like @jguellec
Edited by SmartHomeEddy
@RH_Dreambox @Sjakie @jguellec@antoniopll
Experimenting with InfluxDB and Grafana. Now I put the values of some devices every minute in Influx. But there is a smarter way.
Has anyone used the API for consumption, diagnostics, events, refreshstates and weather to put all the data in Influx?
Like converting the json output of the API to data measurements in Influx?
Quote
No, unfortunately, it's above my level. ? I just log different sensors and the level in the water well (Raspberry + HC SR04).
Thanks you
I am looking for a translation of the api.get to this structure to insert all history values in Influx
    measurement = measurement_name,
    time = os.time(os.date("*t")) * 1000000000,
    tags = {deviceID = deviceID,
    deviceName = deviceName,
    roomName = roomName,
    sectionName = sectionName},
    fields = {value = value}
Hi @10der if you are still there
I would think this should work to get the battery level?
saveByDeviceID("Garage_CO_Sensor_BatteryLevel", 140, "batteryLevel")
No.
yup!
/monthly_2021_02/image.png.c74245afc822c74979f2640a20cb717e.png" />
  • 5 months later...
the script seems doesn't work :
Grafana = ok
influxdb = ok
script = ko
root@XXXXXX:/home/grafana# python /home/grafana/poll.py
Traceback (most recent call last):
  File "/home/grafana/poll.py", line 10, in <module>
    import requests
ImportError: No module named requests
Any idea for helping me ?
thanks in advance
Hi @Manu_31
poll.py is an older variant where data was retrieved from HC2 / HC3 to Influx.
You should use the scene described in the post where HC3 sends data to the Influx server.
So, you don't need to use poll.py.
Hello @RH_Dreambox,
Thanks for your reply.
Here my config in attachement.
In my part (I think)
Grafana and influxdb are OK
Grafana (in attachment) connect to influxdb =ok and request seems to be ok also.
Test influxdb with URL seems to be ok
In my HC3 make a scene and I have multiples error:
- Comment l.16 (same as bello in discussion)  JSon line
- But Power device is not exist (do i mak all my power device or juste one ?)
 And if i comment this line I have another error (attempt to concatenate a nil value (local 'roomID')
Thanks in advance for your help ;)
Hello again @Manu_31
There are a few things you can check.
I see in your picture that you have created a database called HC2 (or have you just copied what 10der shows in their pictures?).
Have you then written the same database name in the scene, where it says "smarthome" by default?
local host = "192.168.1.10"
local port = "8086"
local dbName = "smarthome"
It is also important that you have created a database in Influx with the same name.
You must change the code below to your own ID.
The rows below are intended for a 3 phase energy meter, for example. Aeotec HEM.
If you do not have an 3 phase energy meter, delete or deselect these lines.
(1141, "poll") refers to the energy meter's "main" which is normally hidden.
fibaro.call(1141, 'poll')
fibaro.sleep(1000)
saveByDeviceID("PhaseA", 1149)
saveByDeviceID("PhaseB", 1152)
saveByDeviceID("PhaseC", 1146)
saveByDeviceID("PhaseA_Energy", 1148, "power")
saveByDeviceID("PhaseC_Energy", 1151, "power")
saveByDeviceID("PhaseC_Energy", 1145, "power")
Add the devices you want to log into Influx.
Depending on which devices you have and which version of HC3 you have installed, "power" and "energy" can also be called "value".
This is how I configured some of my devices
saveByDeviceID("Washer", 90, "power")
saveByDeviceID("Dryer", 92, "power")
saveByDeviceID("Platlight", 48, "power")
saveByDeviceID("Greenroom", 46, "power")
saveByDeviceID("Hum_out", 236, "value")
saveByDeviceID("Temp_out", 180, "value")
saveByDeviceID("Lux_out", 68, "value")
Edited by RH_Dreambox
  • 4 weeks later...
I hope everybody's fine.
I came back to my holidays and remake from scratch and have the same error in my HC3 v5.080.12
For answer:
DBName Influx = smarthome
In HC2 scene = smarthome
scene in HC3 same as before.
My errors (in attachment):
 1. Device 1141 does not exists
If I comment this line the script continue to second error
2. (load):93: attempt to concatenate a nil value (local 'roomID')
But if i try since web browers to get this from API it's work.
Do you have any ideas to help me ?
Thanks in advance
BR
    219 is systems room
    please exclude this room in scrip
    Hello @10der:
    How to exclude ?
    Comment wich line, this ?
    local roomID = fibaro.getRoomID(deviceID)
        local room = api.get("/rooms?id="..roomID)
        local section = api.get("/sections?id="..room.sectionID)
    Thanks in advance
    @Manu_31
    ok. use this script
    1st of set own value for init influx
    2nd by default scrip save only ALL temp and hum sensors
    3d if you want save a custom sensor or device look example at the bottom -> comment code
    Edited by 10der
    • 2 months later...
    Good morning at all
    I have a question about transferring data to Influx.
    In the dashboard of @jguellec I saw that the active profile is displayed. As well as the last update and the runtime of the HC. Can anyone help me how to transfer this data to Influx? Which line of code do I have to enter in the script of @10der?
    13 hours ago, KaWi said:
    Good morning at all
    Yes, I can help but later
    I am in busses trip right now
    Edited by 10der
    Hello @10der
    Are you still on a bus trip? ?
    In the meantime, I tried to create the code myself. Unfortunately, I failed.
