Eamonw 0
Good Day All,
I'm new to Fibaro and have purchased a HCL on the confirmation from Fibaro support that it would wllow me to Open and Close Fakro Windows and Blinds through Google Assistant. I've have limited success with this and queries to Fibaro support have been met with stonewalling after the sale was made. They pointed me to the help files, which are not the easiest to follow and are inconsistent but none the less, it seems as if all is set up as required by Help.
I cannot get the Hey Google, talk to Fibaro command to work. The boomy Fibaro voice cannot find any devices. It can find the HCL, but noting attached. Support did say that this was due to the fact that they are "security devices" ? A Window Blind? Stonewalling I think.
Hopefully someone here may have encountered something similar and knows a solution?
Attached is a screenshot of the 4 scenes I have setup in HCL
/monthly_2019_09/1775126179_FibaroFig1.png.d609d1b0b2d3cd20686e87ce228eb355.png" />Next are two screen shots showing the configuration of Blinds Evening which is similar to Blinds Morning – both of these scenes are visible in my Google Assistant and I can successfully activate them by saying “Hey Google, activate Blinds Evening” for example. Blinds Evening and Morning are created using Graphics Blocks while Blinds Open and Close are created using Magic Scenes.
Next are screen shots of the Blinds Open scene (which is the same as Blinds Close except reated using Magic Scenes) – these do not show in Google Assistant - Can't figure out why.
As you can see below, the Blinds Evening and Blinds Morning Scenes show up in for Google Assistant but not the Blinds Open or Close. Even if I copy the existing Blinds Morning or Blinds Evening Scenes (created using Graphics Blocks), giving the copied instances a new name, they still do not show up for Google Assistant.
Lastly is a screen shot of all my devices:
Here are examples of the configuration of 1 each of the blind and Skylight
The scenes I have set up for morning and evening trigger all blinds from the HCL itself. My goal is to be able to activate Blind 1 – 4 (open & close) and Skylights 1 – 4 (open & close) - all individually from my Google Assistant through voice by saying “Hey Google, open Roof Light 1” for example. Has anyone cracked something like this before?
Any tips are appreciated.
Eamon.
