macz3000 1
At the moment, I have a basic scene that turns a light on when a sensor sees motion, then turns off when the sensor has seen no motion for 5 minutes. No problem.
What I need is; if the lights turn on and I don't want them on, I hit the light switch on the wall, the lights turn off and they remain off for 5 minutes. Currently when I hit the switch, the lights turn off but the motion sensor picks me up and turns them straight back on again.
So I'm wondering if I can have a scene that says something along the lines of, "If the lights are on, and Switch 1 Key is pressed, then turn off lights, and..." either disable the scene that uses the motion sensor to turn on the lights for 5 minutes, or disable the lights from being able to be turned on for 5 minutes.
I've also thought about trying to use variables but so far am struggling to figure out what feels like should be a simple solution.
Any help would be appreciated!
