tips:
sample custom weather provider
notice: ONLY local data!
/monthly_2020_05/image.png.5f86b9ee36d940e9dd67c1aef1195463.png" />
Edited by 10der
2 godziny temu, jgab napisał:
Lua has a date function. os.date("*t").month is the number of the month so the below could work.
Next version I will add a 'month' variable that can be used directly.
Thx a lot. Got only one problem...It seems that variable length is limited to 100 characters, any idea to work around this?
Edited by michal85pl
    Right, I have also seen this issue with quickVars in another QA, didn’t realize it would be a problem here too. Let me think about it. Worst case the string has to be added to the code inside the QA.
    it wasn't a problem until now, until I decided to use the date condition, which takes 55 characters ... maybe the implementation of date support in QA code will shorten the need for the number of characters ...
    49 minutes ago, 10der said:
    Just a style of coding. If I need to run a function every x minutes I have moved to using setInterval.
    Ex.
    It's short, keeps the function clean, and allows it to be called from other contexts.
    If I need a timed loop that run on the second and never drifts then I have to use a compensating setTimeout loop.
    1 hour ago, 10der said:
    tips:
    the original weather conditions in QA are wrong, see my posting / fix here
    @tinmanstorm ?
    Ok, new version
    You can use 3 letter english shortnames for weekdays and months with .. test.
    Ex. wed..fri & may..jun
    Guest Freddan67
    10 hours ago, jgab said:
    I loaned a hue white bulb from a friend and it  works flawless in my system. Really strange. Can you give me links to the exact product that misbehaves for you? Can’t sleep ?
    This one but I have tried other lamps also with the same result. Ikea, ledvance (OSRAM). I have reset HC3 to see if it was the one who made it but it became the same. Fibaro's built-in QA works fine otherwise :) but I do not get sensors there, etc.
    3 godziny temu, jgab napisał:
    Ok, new version
    Thank you very much, works without a problem :) as always :)
    Guys!
    what is wrong?
    [06.05.2020] [21:21:01] [ERROR] [QUICKAPP1638]: QuickApp crashed
    [06.05.2020] [21:21:01] [ERROR] [QUICKAPP1638]: /usr/share/lua/5.3/json/util.lua:55: bad argument #1 to 'for iterator' (table expected, got number)
    Well,
    You were thinking right, fibaro.getGlobalVariable returns 2 arguments
    This works
    A single parenthesis around a multi-value return the first value
    Your attempt to using select is wrong, 'select', selects from the number value and the rest of the multi values select(1,3,4,5) == {3,4,5}
    If you want to complicate it you can do like below, create a table of the multi values and select the first index. However, the first alternative is the clean one.
    The other thing is of course why json.decode is so sensitive to extra arguments. Well second argument to json.decode is for parsing options...
    4 minutes ago, jgab said:
    jT = json.decode((fibaro.getGlobalVariable("HomeTable"))) -- YES! it does work
    Jan ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ it doen;t work.
    proofs
    Well, that's an invisible character that got in (the <\194>) - happens sometimes when I cut and paste into the forum. Try to rewrite the first part.
    btw. your SIM works properly
    OMG!
    Thanks!
    @afendikov
    Gues!
    who playing with com.fibaro.hvacSystem
    please please please please
    yes a can crate child with hvacSystem but can't add properties for setPoint etc.
    also this device has 2 buttons bu default but idk what this buttons do
    22 hours ago, 10der said:
    Gues!
    Well, if you set it to
    com.fibaro.setPointForwarder
    you get a little better UI...  The "Advanced" tab has settings for thermostat, time and zone.
    When the "Advanced" tab is selected
    function MyHVAC:getManualTime()
    function MyHVAC:getSetPointsList()
    function MyHVAC:getHeatingZonesList()
    is called to populate the pop-up selectors - however, I can't find a way to get them enabled. :-(
    Youhoeee hehe the first QA who is delivering some result!
    Thanks Jan!
    One remark should the rooms also being listed?
    All my lights are in one room.
    Remark in the HUE-app they are all spread all over the house.
    resp.
    living room
    kitchen
    living room
    Bath room
    Keep going with the good work!
    //Sjakie
    There are previous post on how to call functions in other QAs and receive the result.
    To recap: fibaro.call allows us to call a function in another QA but it does not return a value so we need another method for that.
    There are 2 ways to do it.
    The first is to make the called QA return the value by calling back to the caller with a fibaro.call(callerID,"RPC_VALUE",<return value>)
    The problem with that is that it is quite slow due to the "cooperative" nature of the QA event loop... I can't make it quicker than a 5s roundtrip.
    Much quicker then is to return the result in a fibaro global. Now we are talking about millisecond.
    My new code looks like
    Because this remote call is synchronous we only need to create one global per QA (named "RPC_" + QA deviceID)
    The slight improvement over the older version is that we add a sequence number 'n' to the calls. The problem in the past was that
    if the call timed out , an old, unfinished call, could stuff something in the return variable when we do the next call. Now we check for that and ignore old unfinished calls.( If we are unlucky we get a timeout because the unfinished call overwrites our new value, but at least we won't get a wrong value...)
    The "raw" remote call looks like
    We can add a timeout value that defaults to 3 second. Remote calls need the have timeouts as the called QA may crash and never return a value.
    It's easy to add sugar to the rpc call to define "regular" functions:
    If your QA only answers to remote function calls you only need to implement
    and the functions you "export" need to be global functions, like below because we find them in the global environment _G. You could define them in a table and change the call to get the function from that table instead of _G.
    Only making remote calls will unfortunately  requires some more code to be added:
    If Fibaro will change the fibaro.call to return values they need to do something similar under the surface. There need to be a place (associated to the QA) where the return value can be stored. And they need to decide if it's going to be synchronous value returns like in the above example or asynchronous - some kind of callback function that the caller provide.
    It is tempting to use a quickApp variable to return the value in but it's too slow to access from another QA - and quickApps are also implemented as a list we need to search through - not very efficient.
    make GlobalVariable great again!
    Jan. I do not think what GlobalVariable is good approach.  GlobalVariable is not reentrant (if you understading what I mean)
    UPD:
    Edited by 10der
