    40 minutes ago, marius de jong said:
    i am trying to press a button in a quickapp from a scene but i do not know the action to use.
    in the quickapp it is self:button2Clicked() but i cant seem to get it working from a lua scene to the quickapp
    Do you have a function in the QuickApp that looks like
    then this should work
    or do you have code inside the button that you need to run?
    On 3/28/2020 at 8:09 PM, Krikroff said:
    If it can help...
    Use:
    It's funny that the quickAppVariables panel allows for adding two variables with the same name. I wonder what the thinking behind that was...
    The other thing that's kind of surprising is that they implement it as a list(!). The more variables you have the longer access time. Lua supports key-value association, seems natural for a variable store.
    Also, when a quickAppVariable is changed with self:setVariable a 'DevicePropertyUpdatedEvent' with property = ''quickAppVariables' is thrown with ALL the variables in the data part... not very efficient.
    So, all in all, it feels like performance is not high on the priorities...
    7 hours ago, petergebruers said:
    Thanks for sharing. Your code inspired me to turn that into a "Binary Sensor" quick app and apply a few "optimisations". Well, I think they are optimisations... Please tell me if you do not agree. Firstly I've moved the http client to "self" and create it in "onInit" only once. Because you only need one of those, per app, and it can handle all your requests. No need to create and destroy that HTTPClient each time. Also moved the "header" with authentication because that one also does not change and makes it easier to see where you define the password (if you has multiple http requests, in this example there is only one so not a good example). Actually, you could take it a bit further and store the options or the complete request, because it uses always the same options and url.
    So, I have to throw in my "coding style" too :-)
    I like the "event" model to structure all the callbacks, and I also don't like putting "local" functions on QuickApp as they become the "external" API of the QuickApp.  ( I'm starting to use my own QuickApp helper class that encapsulate some of the standard QuickApp code that's always needed - more on that in another post)
    You can use API also without crateting endless QuickApp functions.
    api.get("/plugins/callUIEvent?deviceID="..<ID>.."&elementName="..<button ID name>.."&eventType=onPressed&value=null")
    Edited by cag014
    I decided to turn my "refreshStates" example (a few posts back) with pseudocode into a working quickapp. What this will to is "listen" to events while at the same time "ticking" a clock every 2 seconds, to demonstrate both are working at the same time. The clock ticks every 2 seconds.
    I also decided to make it compatible with @jgab's HC3 emulator so you'll see a bit of extra code not required on your HC3. You can remove the parts between "if require then" and the next block if you don't need that.
    @jgab would you consider adding b64enc to your emulator? From emulator 0.75 onwards, encoded credentials are available as hc3_emulator.BasicAuthorization
    At the moment, running under emulation version 0.75, the clock tick has a 1 second resolution, thanks to a new feature introduced in that version (hc3_emulator.asyncHTTP=true) by @jgab
    I failed to come up with a good name for the variable "req". If someone has a better idea...
    Just to be clear... I am not suggestion people should use tick() as a clock (unless you make it really slow eg one tick per minute). The idea is that production code acts upon the state updates (eg motion sensor breached, now printed merely as "got state update") then decides if something needs to be done after a certain time (eg turn of the light) and uses fibaro.setTimeout to schedule that. I don't have a working example of that, because until now I've use the blocking "api.get" and relied on its (undocumented) 30 s timeout to do time related calculations.
    Edited by petergebruers
    Nice example.
    I have solved that by Quick:App which updates random value every 3 seconds. In this case refreshState doesn't stuck anymore.
    @jgab would you consider adding b64enc to your emulator? Or a function or a (table) variable to retrieve the "basic auth string" in some way?
    Yes, I will do that. I will provide a variable in hc3_emulator with  the basic auth string to the HC3. However, it's purely for offline testing as code moving to the HC3 will not have access to. it.
    At the moment, running under emulation, the clock does not tick, I have not investigated this yet.
    When I run your code in the emulator the clock ticks. Would be interesting to know what's different (I took away your includes/requires and use my own - are you doing something strange in CheckGlobalLeakage? )
    'req' is as good as any. I guess there are more local variables needed in a full app and maybe scope them all in a local table name "App" ?
    I'm doing my own "App" class where I can store nice to have data and add local functions without polluting QuickApp.
    Mine works with CheckGlobalLeakage too, so that's not it - what do you have in HC3settings? :-)
    Btw, I get an read exception for 'PROXY' deep inside http.lua
    ...dio.app/Contents/ZeroBraneStudio/lualibs/socket/http.lua:189: attempt to read undeclared variable PROXY
    Thanks, maybe my comment was imprecise... It does tick, but ticks only after refreshStates reports an event. So it does not tick every 2 seconds as it does on HC3. I can investigate this later.
    Ah, I didn't see it because I have too frequent events.
    Ok, emulated net.HTTPClient() is not asynchronous. That's the way luasocket is implemented. To take in a non-blocking socket lib will create platform dependencies - or at least a more advanced configuration of fibaroapiHC3. Let me think about it.
    Ah yes "socket" is blocking. Don't worry too much about it. At least not for my specific case, it is not important. To test "offline" and get things right I guess I will have to 'inject' fake data anyway. Debugging with time is always a bit tricky. I know you have provided things like "speedup" of the clock but I haven't used that trick yet.
    Yeah, it seems you can set a global to force a proxy. I think by modern standards that is considered a bit ugly, but once an API is public it is probably hard to revert stuff users (might) rely on.
    You have an updated version of CheckGlobalLeakage.lua ?
    I don't think it works, When adding a variable with the same name the value is simply overwritten ...
    If you use the web tab to add variables manually, you can add multiple with same name. (5.021.38)
    I have updated my refreshStates example... New code after @jgab released a new version of his HC3 emulator. Clock now ticks offline and code can be simplified because we no longer need base 64 encoder.
    You are right ?
    /monthly_2020_03/QA_Vars_bugs.PNG.07dbde9b73675d99eccbe4ec39d03b79.PNG" />
    Question:
    In the debug we see "onAction" and "onUIEvent" traces and debugs...
    Ex.
    [13.04.2020] [18:17:18] [DEBUG] [QUICKAPP263]: onAction: {"args":[513],"deviceId":263,"actionName":"removeChildDevice"}
    Is there a way to intercept these actions?
    It would be nice if defining QuickApp:onAction(deviceId,actionName,args) I would get the action.... but that doesn't work.
    At the moment I have a device with many children and when I remove a child device with the web UI trashcan I'm unaware of it - I can scan the childDevices list all the time but it feels a bit unnecessary.
    Anyone with some insights?
    Btw. more questions:
    'core.EventTarget' and 'Device' are classes. What's their purposes?
    ;) by design i also expected that!  but you must declare the name of the event handler directly in the control
    What is interesting is to be able to manage several buttons with the same method, for example: a QA with 10 buttons btnRadio1, btnRadio2, btnRadio3 ...
    it would be nice to be able to subscribe to an event for that ;)
    I saw that too, for me, 'Device' hum ... i suspect :
    Yes, for the onUIEvent I get it, but what about the 'onAction' event?
    Th 'onAction' is logged when QuickApp:<functions> are called among other things - so it seems like it is some kind of callback "inside" the QuickApp class.
