    1 minute ago, cag014 said:
    But all that still doesn't explain why takes 5 seconds to execute API or fibaro.call inside QucikApp.
    Well, it depends on how they implemented to "cooperation" between incoming calls/events to an QuickApp. I believe that they hang waiting for the receiving QA the ack the call, but because the receiving part is the same QA that is busy waiting for the ack it hangs - and they have some timeout mechanism that saves them? I can only guess - but it's atypical source of issues when you accidentally call yourself...
    We seem to think the same... Calling a "function" in Lua never leaves the interpreter, but doing "api call" goes through a http client, a http server and talks to that your same process but via a long winded road... And api call is blocking.
    What's this event?
    Unhandled event:{"type":"RoomModifiedEvent","data":{"id":219}} -- please report
    This occurs each room.
    room 1 to the end.
    9 minutes ago, petergebruers said:
    A bit off topic but I think we've all been on this planet for a while and I guess some of our ways of thinking are "learned" while some simply reflect how the human brain works.
    When I try to explain issues to my wife, I often tell her we are used to "following recipes", like preparing "béchamel sauce".
    Ever tried to write a recipe in "recursive style"? Or "functional style"? Maybe there is some "callback style" in recipes eg  "after 10 minutes, take the pan and stir" =: setTimout with callback :D
    No matter how hard I try (and I've written small programs in Erlang so I did try very hard :D ) to get fluent in different paradigms - I always go back to "imperative". For multitasking, I am inclined to believe "Communicating sequential processes" is a viable option, like used in Erlang and Go... but I am not a professional programmer so no experience with practical implications at all.
    I saw that and I would recommend other users to have a look at it. It indeed captures part of what I said...
    Yeah, and sometimes recursion works, but if you are not careful it really blows up your stack because it does not really convert to a loop - instead it really causes each function call to nest another... and another... and... Until the interpreter shuts down your process.
    Thank you for confirming that.
    Personally, I think it is good thing, that QuickApp:onInit() blocks every other part of the FQA. Because you would probably set things up before everything else runs.
    Suppose you use "X" in a button, and by some silly coincidence the user clicks when you are halfway through your QuickApp:onInit() and X has not been set up yet?
    Indeed it does not, but it reminds me of the 10 second "hangs" we sometimes have on HC2 when a scene gets killed.
    I have no access to the "guts" of a HC3 so this is big speculation, but maybe and "api call to yourself" causes the HC3 to reload/redo something, cause a time-out and a retry "behind the scenes"?
    Maybe it is possible to discuss that with Fibaro (through their beta bug tracker I mean)... So "api call" to another device (any typ) is OK but "api call" to yourself (your FQA) = 5 second delay.
    ...and I do love recursions :-)
    setTimeout & friends are nice as it is almost like recursion but not - no stack that grows - and you have to carry your own stack if you want to collect some result.
    However, Lua is tail-recursive so it won't eat stack if the recursive call is the last in a execution branch in the function. (and that goes for A calling B calling A etc) - so it's usually easy to avoid stack blow-ups.
    5 minutes ago, rangee said:
    What's this event?
    room 1 to the end.
    Yes, it's when you modify rooms - you are running ER4 or some of the example code I posted?
    So, you can ignore it - I will add it to the next release so it won't be so noisy about it.
    It was a way for me to be aware of new types of events... I haven't seen them all yet ;-)
    Thanks for reporting anyway.
    Have reported about that ages ago.... no response
    1 hour ago, jgab said:
    Yes, but you do that loop with setTimeout or setInterval.
    please be carefull with setInterval, set a variable with the timer id and use clearTimeout function to kill it ;)
    3 hours ago, cag014 said:
    Is anyone has knowledge how to press button inside QuickApp (beside using API, which takes 5 seconds)?
    I asked the question, here is the response of the SW team:
    Quote
    It’s taking so long because there is 5 s timeout on communication with QuickApp process. QuickApp process is unable to handle this because it’s still processing fibaro.call.
    @Krikroff thanks, so this answer settles it and confirms our suspicions "t’s taking so long because there is 5 s timeout on communication with QuickApp process. QuickApp process is unable to handle this because it’s still processing fibaro.call". So this style of programming is a no-go because you are essentially deadlocking yourself. The whole FQA has to be treated as "cooperative multitasking".
    What's wrong with clearInterval(<ref>) ?
    ...anyway, all my setInterval's run forever.... :-)
    Quote
    Yes, and they can solve it in two ways. Either discovering that they call themselves and short-cut it (trivial inside fibaro.call), or implement some kind of message-box to use as a synchronisation mechanism behind the scene.
    Quote
    Thanks.   (So in QuickApp fibaro.call commands are useless.)
    Not useless in general, it is safe to use them if the target is another device (or room or whatever api you want to call). It is not safe to use them "on yourself"
    I'm only using setUpUtilities function.
    I found out when RoomModifiedEvent happen.
    This happnes when value of the room temperature sensor changed.
    And this affect to all room.(bcz I added only one temperature QD.)
    Only to inside the QuickApp to itself. Between QuickApp they are pretty fast.
    Between QuickApps they are pretty fast
    Using fibar.call should be used only to call actions from different devices or scenes and never to call actions on themselves.
    Thanks, I didn't think of that but now rooms can have associated temperature sensors - So when the temperature changes you get a RoomModified event? Funny :-)
    When I read your original post I rounded that to 15 calls per second but I had 2 questions, how much CPU does it use and does it scale. There are 4 cores so possibly running that test from/to multiple FQA gets even better numbers.
    Yes. Mayby humidity sensor and light also affect to RoomModified. (maybe..)
    Because there are 3 options when editing room.
    Main temperature sensor, Main humidity sensor, Main light sensor.
    Yes, in theory. I don't know if they give us all the cores or keep some for themselves ;-) ?
    Do they "nice" the QA/scene processes?
    • jgab changed the title to SDK for remote and offline HC3 development.
    But setTimeout & friends is not about recursion. The function calling setTimeout(f,x) exits before the function f is called.
    Not recursive in the true sense like the classical Fibonnaci example
    function fibonacci(n)
        if n<3 then
            return 1
        else
            return fibonacci(n-1) + fibonacci(n-2)
    But it  the sense that your timer or http handler ends by calling http or timer again.
    I am pretty certain you can shoot yourself in the foot with net.HTTPClient() - someone contacted me about this but I cannot find back a good example.
    The issue is with the lifetime of the objects you pass around.
    It ends with a Lue interpreter crash because it runs out of handles or memory.
    As a rule of thumb, I tell people they should have only one of these in there code, if they have more than one then they are wasting resources:
    local http = net.HTTPClient()
    That is probably a white lie but quite a few users seem to think you need a net.HTTPClient object per request but that is not the case, one object can handle all your requests.
    Edited by petergebruers
    I haven't seen that behaviour. It but instead of looping back from the call-back handler one can do a setTimeout(cont,0) to exit the call-back handler and continue in a new context - no strings attached. Which is usually what happens the way I structure my code.
    If they have a bad call-back mechanism (from C?) I guess it can cause issues.
    In fibaroapiHC3 I have a library that do http requests synchronous - so I simulate the asynchronous behaviour by calling setTimeout with s small random delay - just to make it realistic :-)
    Yes, one object usually is enough - not sure about passing options to net.HTTPClient(options). Are there any option that  can't as easily be provided in the request?
    edited -- gray wizard killed me
    Edited by tinman
