    3 minutes ago, petrkl12 said:
    @jgab
    I want to setup set credentials in fibaroapiHC3 but it doesn't work. Could you try it? or paste working example how to add credentials to fibaroapiHC3 ?
    You need v 0.62
    The way I would do it is to create a file, credentials.lua and add
    and then at the top of the scene/QA do
    Alternatively, without a credentials file (but it's a really good place to store credentials to other systems too)
    at the bottom you need to start with
    Does that work for you?
    Yes, it works now! Thanks a lot.
    @jgab
    in newest version there doesn't work getVariable - result is nil
    In previous versions it was OK
    9 minutes ago, petrkl12 said:
    @jgab
    Eh, it works for me...(!)
    Are you are running against a proxy? I tried both with and without and get the expected result.
    How does your 'hc3_emulator.start{...}' look like?
    my start ...
    if dofile then
      hc3_emulator.start{
        id=32,
        poll = 1000}
    You want it to fetch the value from the HC3?
    The new default is that it will only fetch the value from the HC3 if it has a "proxy" on the HC3.
    E.g.
    but then you don't get to chose the id (because it is generated when the proxy is created).
    And in your case you already have a QA on the HC3 with id 32 that you would like to fetch the variable from?
    So, you have to trick the emulator to believe that there is a proxy even though it hasn't created one..
    Have the same start as you had before, so no proxy is created, but when you enter QuickApp:init() set plugin.isProxy=true
    that will fool the emulator thinking there is a proxy with id 32 on the HC3 and call it.
    Let me know if it works.
    Note. the code looks like
    so if plugin.isProxy is set to true it will fetch the value from the HC3 otherwise the local _quickVars table.
    Yes
    Yes
    It works. Thanks
    I think it could be perfect to add possibility to start it without adding line to Init().
    11 minutes ago, petrkl12 said:
    Yes
    Yes
    It works. Thanks
    Ok, next version will have an option to start{...}
    On 3/2/2020 at 9:08 AM, AutoFrank said:
    From Krikroff
    I use this little trick also in the case of a device with a fixed value of type power, to temporarily replace the value:
    And play with:
    Edited by Krikroff
    • Like 3
    Hi jgap
    Home center 3, 1 person waiting for your er4
    When can I use it?
    From your fans
    6 minutes ago, minsad79 said:
    Hi jgap
    When can I use it?
    From your fans
    Can you run the ER4 quick app linked i this post? If not what error messages do you get?
    If you execute the er3 rule of Home Center 2
    The following error
    [DEBUG] 2020-03-08 04:12:31 pm: [ERROR] in 'Rule: 1 [459: breached => 494: on]': {"msg": "Error executing instruction: '["% prop ", 1," breached "] '", "ERR": true, "src": "Rule: 1 [459: breached => 494: on]", "err": "./ quickApp.lua: 1888: attempt to compare string with boolean "}
     rule(" 459:breached => 494:on ")
     rule(" trueFor(00:01,459:safe) => 494:off")
    If you apply the rules used in Home Center 2
    Error in er4 quick app
    The following error
    Thanks, will fix...
    16 hours ago, petrkl12 said:
    New version v0.64. New start option 'quickApp'. Connects to existing quickApp on HC3 with given id.
    Is anyone has knowledge how to press button inside QuickApp (beside using API, which takes 5 seconds)?
    Edited by cag014
    Do you have code inside the button so you need to actually activate the button?
    If you have moved the the code into "function QuickApp:buttonClicked()" you can call it with self within the QuickApp and fibaro.call(id,'buttonClicked') from another QuickApp...
    Did I understand you?
    Yes, I have global definitions for many tables that I don't wont to keep inside QuickApp. (too many lines to scroll)
    Edited by cag014
    7 minutes ago, cag014 said:
    Yes, I have global definitions for many tables that I don't wont to keep in side QuickApp. In addition have found very interesting advantage by keeping definitions there. I can change global variables, press the button and "main" QuickApp starts to use it on the fly.
    Yes, I have though about storing functions in them too... (You can update the uiCallbacks table of the device).
    It's a bit inefficient though for large code blocks as they probably do a loadstring() each time the button is pressed.
    Do you need to hide the buttons or is the switching of tables part of the user interaction?
    Is it part of user interaction... the idea that when user needs to configure variables, he can open the button code and change it without going through entire QuickApp code.
    The API call works fine, but it takes 5 seconds per button..!! Interesting by using same API in scene, it works very fast.
    Edited by cag014
