Please tell me, what am I doing wrong. I'd like to get value from one QA and use it in another one. I'm total noob in lua, and i'm trying to integrate my Shellys with HC3 so I am asking for your understanding.
on source QA i get variable from json:
self.httpClient:request(url,
        options={
            method = "GET"
        success = function (response)
            if (response.status >= 200 and response.status < 300then
                self:debug("OK: " .. response.data)
                jS = json.decode(response.data)
               energy = (jS.meters[1].power)
               if (jS.relays[1].ison) == false then
                    stat = "Stan przełącznika: wyłączony"
                    self:updateProperty("value"false)
                elseif (jS.relays[1].ison) == true then
                    stat = "Stan przełącznika: włączony"
                    self:updateProperty("value"true)
                self:setVariable("energy", energy)
on destnation QA:
function QuickApp:onInit()
    self:debug("onInit")
    self:debug(fibaro.getValue(110, energy))
Debug:
[ERROR] 12.03.2020 19:57:01: [LUA Code] line: 18 Wrong parameter type, string required. Provided param 'nil' is type of nil
You are setting QA variable? self:setVariable("energy", energy)
It is a local variable for specific QA and cannot be accessed by other QA.
And then you're trying to fibaro.getValue()  !? this is not a command to get variable in any case.....
May I suggest set in energy QA (I hope you've created QA as energy meter type)
self:updateProperty("value", energy)
self:updateProperty("energy", energy)
now from destination QA
 self:debug(fibaro.getValue(110, "value")) or
 self:debug(fibaro.getValue(110, "energy"))
Edited by cag014
7 minut temu, cag014 napisał:
first of all energy is a string type.
now i've got
[DEBUG] 12.03.2020 21:27:26: nil
1 minute ago, michal85pl said:
now i've got
No, my bad...
please look again on my answer.... have edit it
Edited by cag014
No, my bad...
still the same, "nil"
but my source QA is binary switch (not energy meter), from which i decode energy consumption from json
No, you need to define it as energy meter. binary switch has boolean values only (true or false)
Please create a new QA and copy your code.
But my source QA is binary switch because i need to control its relay(s)
My idea is to read energy consumption in source QA and then use it in destination QA,  to avoid creating further queries in  destination QA (defined as energy meter). So question is, is it possible?
Yes it possible... two options
1. Use global variable to store and retrieve energy consumption.
store -> fibaro.setGlobalVariable("energy",energy)
retrieve -> fibaro.getGlobalVariable("energy")
2. You can call function in destination QA from source QA to save energy value or to do what ever you need.
destination QA: (assumprion id = 100)
function QuickApp:getEnergy( energy)
your code
source QA
fibaro.call(100,"getEnergy",energy)
Edited by cag014
store -> fibaro.setGlobalVariable("energy",energy")
your code
source QA
the first option still returns "nil", second works great.
Thank You very much for help
Just out of curiosity, in first option: what type of global variable you have defined?
You should use standard type.
 recreating global variable solved problem with "nil", now it works in both options
Great.... glad you have sort it out.
Edited by cag014
W dniu 1.03.2020 o 12:26, tinman napisał:
it looks that one can add extra interface to QuickApp device, however for some reason the QA behaves strange if i called self:addInterfaces({"power"}) in onInit without any check, but with small check seems to work. Now my binary switch have power property:
@A.Socha anything against (from Fibaro/design point of view) calling self:addInterfaces({"power"}) in QA to add extra interface?
Great option...it works without problems
    In would be useful if conditions in scenes allowed for specifying a condition that would be true if the condition had been true for a specific time.
    In addition to "any" and "all" there could be a "trueFor", with a property "time" set to a time ex."00:05"...
    Ex. if a motion sensor has been safe for 5min, or if a set of motion sensors have been safe for 5min etc.
    Anyway, this is a thread about QAs, so let's do the second best thing...
    We compile expressions of type #<eventName>/<time to be true>/<interval for checks>/<expression>
    We actually put the rule in the QA'a quickappVariables
    value:00:05/2/100:safe & 101:safe & sunset..sunrise
    Anyway, we compile the expression into a Lua function that looks like
    numToBool converts a number to true or false if its >0, sunset and sunrise are variables bound to resp. time. (we have 'midnight' and 'now' also)
    We run it at every interval (2s in this case) and when it has been true for 5min we emit a CustomEvent with name 'test'
    We choose the interval depending on how quickly we need to be notified that an expression has been true.
    This allows us to use most of the power of Lua to craft our rules, we can do
    etc.
    The total code when we don't have to write a parser from scratch and interpret the result becomes quite compact (that's why load/loadstring would be appreciated)
    This code works as is but would probably need some more error checks etc before being "production ready"
    (Sorry for the long listing, but there are some techniques in the code that code be worth stealing...). QA attached at the end.
    Updated with same fixes and 'repeat' options.
    value=R00:05/2/88:on
    The starting 'R' indicates that the rule should continue to fire events every 5min the expression is true.
    Good to have if you want to have notification and reminders if a door/window is left open.
    New version. May 4, 2020
    supports day and month in .. test.
    Ex.
    mon..fri
    may..jun
    Anyone able to help with simple HC3 Lua? Im trying to control my Lightwave RF and need to create new VD's. Ive tried all sorts but nothing working!
    Examples of my HC2 Lua codes (which work) are:
    socket = Net.FUdpSocket()
    socket:setBroadcast(true)
    socket:write("111,!F*p|<FIBARO>", "255.255.255.255", 9760)
    socket:write("111,!R2Fa|<cr>", "255.255.255.255", 9760)
    so all im trying to do is send a command to a local IP and port?
    Should be simple but im struggling!
    Hi, please see the TCP example quickapp at the bottom of this page:
    I use it as a base to send IR commands through TCP to a port.
    If you at a later stage need to call QuickApp buttons from a scene, be sure to set up the button functions in the main code like this:
    Edited by robw
    Yes
    I tried this, so input the port and ip in variables. Touched nothing else (main code untouched) and in the button code I put:
    self:send("111,!F*p|<FIBARO>")
    But the device is not getting the command. Not sure what I'm missing...
    UDP not supported Yet !
    AH!! Thanks for update. This is disappointing indeed!
    I made a long post on how I thought QAs worked (internally) and why it is a cooperative multitasking environment and why we need to use setTimeout to give time to other tasks , like clicking buttons, calling QuickApp:functions etc.
    One thing that we see is that when we do a fibaro.sleep() every other task stops - no calls to QuickApp:functions and setTimeouts will not be called (they queue up and will be called when the sleep is over).
    So here is an implementation of the concept. A minimalistic QA environment simulator. If you run this code in a Standard 5.3 Lua environment that don't have setTimeout etc.  (real computer, not the HC3 :-) ) you will see the loop in 'my code'  running every 2s, and the QuickApp:turnOn command in 'my code' that is scheduled 5s after start will execute when its time comes.  (no extra libs needed, this is plain Lua)
    (note this example timer has a resolution of seconds. It's easy to change to use os.clock() and get milliseconds)
    However, we are doing it a little bit better, our fibaro.sleep() gives time to other tasks to execute - like the "incoming" 'turnOn' after 5s.
    This improvement would be easy to do for fibaro, and it would be easier for users to write code, and not be surprised why everything "stops". (In fact, every fibaro.* call could yield to give time to other tasks to run if wanted)
    I also added implementations of setTimeout and setInterval too, just to show how it fits into this model (in reality a bit more involved, but this works to demonstrate)
    So I repeat it again, Fibaro should enable Lua's standard coroutines. People that knows how to use it would produce much better code and we would not need to break our necks to achieve things we need to do today. If you need to do a more elaborate communication protocol over sockets requiring various timings etc - doing it in a coroutine with sleeps is just very natural - juggling timers/setTimouts are not. Why not make the HC3 an easy environment to create great code and functionality?
    Once back in the time coroutines had some sandbox/security issues but now with 5.3 it's classified on the same level as the Math library. With coroutines we could easily wrap HTTPClient() into a synchronous FHttp() function, without stopping other cooperative tasks - once again making life easier for coders.
