Guest Freddan67
4 minutes ago, jgab said:
On my machine (Mac/Safari) they behave correct (both in "device list view" and "House overview view"). On the web UI the on/off buttons on devices that are mapped to com.fibaro.philipsHueLight have ugly buttons that don't show state in the UI, only the color ring shifts to greys when it's off. All other lights in the web UI has on/off buttons where the button selected turns blue. And they all work for me. Disclaimer, I don't have any lights of type "Color light' but when I map my "Extended color lights" to the same class they behave well.
In the app it's a different story,  it seems like on/off is not synced well for any light - all my lamps start off as ON even though they are off.
Ok. I've only tested with Chrome and PC. I'll test with my mac and another browser too.
    FYI, Chrome on (my) mac works too..
    Guest Freddan67
    Get the same no matter what I try so there is probably something wrong with me if it works for you
    Guest Freddan67
    I can be something on the track, brightness is set to 0 when I turn on the lamp I change it and the status of the lamp changes. If I turn off the lamp, I need to turn brightness down to 0 again for the status to be changed to off
    These are "Color lights" hue types?
    Guest Freddan67
    No just "white"
    No just "white"
    Of hue type "Dimmable light" and mapped to 'com.fibaro.multilevelSwitch'?
    Guest Freddan67
    It seems that whoever it works on looks this way
    correct
    These do not change the status no matter what I do, they are of the "lightstrip"
    For me the white/multi level witch works ok
    and I can also click on the little lamp to switch on/off.
    Guest Freddan67
    Weird
    I'm not going to disturb you anymore with my problems. Thanks for all the help I get to use fibarose's built-in for so long until I find something that works
    5 minutes ago, Freddan67 said:
    Weird
    Ah, if you turn brightness down max it becomes 0 and that is interpreted as off. I will change that so the brightness is at least 1, then the lamp icon will continue to be lit.
    Ah, if you turn brightness down max it becomes 0 and that is interpreted as off. I will change that so the brightness is at least 1, then the lamp icon will be lit.
    I don't have a lightstrip but they should behave like a "color light" according to the manual.
    Guest Freddan67
    Lightstrip retrieves correct brightness but still appears as off
    You could try this version
    - maybe it works better (at least it doesn't turn off the light icon when brightness is turned down to 0) - made some other small adjustments to 'Color light' too.
    I noticed that if I make a change in the Hue app it can take ~4s before the QA's state updates.
    No need to reinstall the lights - just copy paste code into the existing Hue QA.
    You are running the latest fw version for HC3 I assume?
    Guest Freddan67
    Thanks. I'll try as soon as I get home again. Yes I use the latest version
    Guest Freddan67
    Same issues
    Tip.
    We can set an UI element with self:updateView(<element>,<type>,<value>)
    but there is no ready made function to get the value. We do get the values in the button/slider callbacks, but sometimes it would be nice to get the value directly.
    To get the value or text from an UI element
    It take the deviceId as the first argument.
    Ex.
    print(getView(39,"myLabel","text"))
    There is an issue with slider element. They seem to have troubles updating their values when activated (moved)
    I have noticed that explicitly updating the view when a slider is activated helps to set the 'value' field of a slider.
    Ex.
    • Like 5
    W dniu 17.03.2020 o 00:24, jgab napisał:
    In would be useful if conditions in scenes allowed for specifying a condition that would be true if the condition had been true for a specific time.
    In addition to "any" and "all" there could be a "trueFor", with a property "time" set to a time ex."00:05"...
    Ex. if a motion sensor has been safe for 5min, or if a set of motion sensors have been safe for 5min etc.
    Anyway, this is a thread about QAs, so let's do the second best thing...
    We compile expressions of type #<eventName>/<time to be true>/<interval for checks>/<expression>
    We actually put the rule in the QA'a quickappVariables
    value:00:05/2/100:safe & 101:safe & sunset..sunrise
    Anyway, we compile the expression into a Lua function that looks like
    numToBool converts a number to true or false if its >0, sunset and sunrise are variables bound to resp. time. (we have 'midnight' and 'now' also)
    We run it at every interval (2s in this case) and when it has been true for 5min we emit a CustomEvent with name 'test'
    We choose the interval depending on how quickly we need to be notified that an expression has been true.
    This allows us to use most of the power of Lua to craft our rules, we can do
    etc.
    The total code when we don't have to write a parser from scratch and interpret the result becomes quite compact (that's why load/loadstring would be appreciated)
    This code works as is but would probably need some more error checks etc before being "production ready"
    (Sorry for the long listing, but there are some techniques in the code that code be worth stealing...). QA attached at the end.
    Updated with same fixes and 'repeat' options.
    value=R00:05/2/88:on
    The starting 'R' indicates that the rule should continue to fire events every 5min the expression is true.
    Good to have if you want to have notification and reminders if a door/window is left open.
    New statewatcher compatible with 5.03.45
    Is it possible to add a date range to the conditions? so that, for example, the heating does not turn on from May to October despite the lower temperature? Or is it necessary to use the built-in date range block as the second condition for running the scene?
    I wanna dancing change icon for my generic QA:
    1) find any multilevel sensor.
    2) found MS6 - humidity
    3) add icon
    4) added
    5) no. i do no want change. just close
    6) /api/icons find last User*
    7) PUSH number to brain :
    ? goto own QA.
    where 1040 is POP from brain number :)
    9) ctrl+S
    10)
    Edited by 10der
    Lua has a date function. os.date("*t").month is the number of the month so the below could work.
    Next version I will add a 'month' variable that can be used directly.
    On 5/1/2020 at 10:28 AM, Freddan67 said:
    Same issues
    I loaned a hue white bulb from a friend and it  works flawless in my system. Really strange. Can you give me links to the exact product that misbehaves for you? Can’t sleep ?
