it looks that one can add extra interface to QuickApp device, however for some reason the QA behaves strange if i called self:addInterfaces({"power"}) in onInit without any check, but with small check seems to work. Now my binary switch have power property:
/monthly_2020_03/image.png.c5c762e67cd1eab282d06d1690b99cd0.png" />
@A.Socha anything against (from Fibaro/design point of view) calling self:addInterfaces({"power"}) in QA to add extra interface?
  • Like 4
  • Thanks 2
    I have added "battery" and set the "batteryLevel" property on a Hue proxy QA - works fine :-)
    @jgab I have read all your posts with great interest. For several reasons I have not been able to join the discussion. I think you deserve plenty of "likes" so I will now randomly tag some of your posts to show my appreciation.
    I believe that we are a few in the forum that tries to do a little bit more "advanced stuff" and it's good if we share our knowledge as the documentation kind of stops at a basic level.
    I try not to complain so much in this thread (I have another thread for that ;-) ) Also trying to keep an index in the beginning of the thread pointing to the main insights/contributions. Now I'm adding a link to @tinman's 'add Interface' finding.
    I'm pleased to have managed to get @tinman into the thread - he has some good insights. :-)
    I was told on the HC3 beta tracker it was possible to mix a button and a label on the one line in a Quick App
    /monthly_2020_03/image.png.e2ddbeb432a5f0e66f50066dd0341cc8.png" />
    Does anybody know how ?
    You can if you create or modify the layout with the REST API.
    I don't think there is a way to do it with the UI.
    You can also mix slider and label on the same line
    Thanks @jgab, I didn't think of that approach and will take a look
    BTW - This is a really great post and should help a lot of people from beginners to experienced users
    All credit deserved..
    as already mentioned here
    one can create custom QA, based on already existing device type, e.g. Fibaro Keyfob.
    Atatched my keyfob QA, with 1x,2x,3x,Hold Emulation.
    /monthly_2020_03/image.png.bc57b278243322b6b00538d80701c00b.png" />
    One could add as well keysequence etc., but i haven't
    Edited by tinman
    Just restricting the thread by moving out this post from the first post (where I will try to keep an index of the main insights) - Would be nice with a Wiki...
    Logging in QuickApps (and Scenes) are a bit lackluster. No html tags, no line breaks in strings, you can't event indent the string with preceding spaces. When I've coded quick apps now I have created my own log function (and patched QuickApps' self:debug) to make log output a bit nicer. There may come better log formatting support in the future (Logger.* doesn't do anything in QDs what I can tell)
    The simplest way is to do is like below. Add the missing fibaro.debug(...) that exists in scenes, and also add a convenient fibaro.printf(fmt,...) that formats its arguments with string.format. We also store QuickApp's 'self' variable in Fibaro.QD so we can access it from regular Lua functions later without having to pass 'self' around - or litter the global namespace more than necessary.
    A more elaborate debug add-on that I use in my own code looks like:
    (sorry for the formatting)
    If called from QuickApp:onInit() setUpUtilities(self); self.debug = function(self,...) Log(LOG.LOG,...) end end
    it will create a function
    Log(<tag>, ...) that logs the output formatted  (self:debug(...)  is the same as Log(LOG.LOG,...) )
    Log is a global function in the QD so no need to carry around QuickApp's self to do debug...
    Ex.
    and it will print
    it formats the arguments according to string.format rules.
    The tags defined are LOG = { LOG="[L] ", ULOG=" ", SYS="[Sys] ", DEBUG="[D] ", ERROR='[ERROR] ', HEADER='HEADER'}, and are easy to extend with more.
    will print
    When I start up my "QD project" the log looks like
    There is also a Debug function
    Debug(<flag>,...) is like Log(LOG.DEBUG,...) but only prints if <flag> is true and prints with the prefix [D]
    It automatically does json.encode on table values before printing them.
    It breaks up the line if it contains "\n"
    The last thing the code does is that if a table has a __tostring field in it and it points to a function, that function is used to format the table. (It actually patches tostring)
    Ex.
    will print
    ...which is handy if you have your own defined data structures...
    @jgab
    Could you please add "addInterfaces" to fibaroapi ? Thanks
    I am looking to write to the space under the QuickApp name
    /monthly_2020_03/image.png.b5c6366a68a61834ea6f857f026fd915.png" />
    Dimmer 2  s an actual zwave device so the off, on and % are there by default
    Office Window is of type window sensor and shows the last breached
    Hall Lamp is a binary switch QuickApp (of a sonoff device) but I am looking to write to the space under the name like fibaro:log or ticking the Main/Fav box in a VD
    Anybody know if this can be done ...?
    On 3/1/2020 at 5:19 PM, petrkl12 said:
    @jgab
    As part of hc3_emulator.createQuickApp and hc3_emulator.createProxy ?
    for ZB to be able to call it
    Ok, v 0.42 has self:addInterfaces(list)
    My experience so far:
    -It seems to depend on what type the QuickApp is, and then the UI fetches appropriate property and displays it.
    -I have QuickApps for Hue devices of type lux, motion, and temperature and the UI fetches the values from the property ('value' in this case)
    -There seems to be nothing in the device structure that hints what value should be displayed and how it should be interpreted.
    Another observation:
    In plugins on this line name of device shown... by changing the name this line changes accordingly.
    Thanks @jgab
    I'll log an enhancement/query on the beta page
    It seems you can't modify an already uploaded device
    (I have tried  /devices/<id> without any luck, always gets unknown device type)
    However, you can download the fqa, and modify the viewLayout by hand.
    I have some code in fibaroapiHC3.lua which allows me to dynamically create a QuickApp and where I can specify the UI elements.
    I have discovered that there is a single and multi-select popup possible.
    And also to add an image... the latter needs some investigation how to scale it.
    hmm, it must be possible to modify properties.viewLayout
    Thanks @jgab
    I had also started to look at this and found I could modify labels and buttons sizes but could not see a logic to the layout code .
    I was going to back to it during the week but will use tour code to see if I can find a way..
    Thanks for sharing ....
    Edited by AutoFrank
