55 minutes ago, rangee said:
r u looking for this?
now u will get ?
works !!!
thanks!!!
38 minutes ago, rangee said:
@tinman @SmartHomeEddy
Use this for device unit.
nice trick, i played with uniceode, but it got always uppercase converted, yeah 0xE3 0x8E 0x8D is case independant only lower case.
Edited by tinman
what a fail, fighting since hours with Doorstation QA.
The idea behind - QA UI with 2 button, 3 labels, and some code to connect, react on buttons (open gate 1 / gate 2), show call status.
Currently QAs does not support (yet) intercom/camera/image, so i need (once code is ready), to replace one of these labels with type=image instead of label. Of course such code need some extras as well, to allow the image UI type to get updated, like self:updateProperty("ui.imageStream.source", path-to-mjpeg-stream), and it make sense to add some initial interface like voip (before init, so added into fqa later with text editor).
Of course one can't edit the code anymore in such patched fqa file, because the QA visual editor will reset all UI elements, but i don't see this as a real problem, once the UI elements has been arranged and code is working, one don't need to edit anything anymore.
The user need only to import such QA, change IP and credentials local variables, and save it - which does not affect UI elements.
/monthly_2020_07/image.png.754530a9ba3da768a4496b8451d701d9.png" />
Btw, it is LunaIP L-TS-5700 (based on Dahua VTO2202F, with some firmware extras requested by us, like "send http request when something happens..."), anyway.
As one can see picture is there, but buttons code is giving me 401 and after close look recognized why.
It is the Digest auth, which is supported for cams, but not for QA code itself, which of course is bit misleading, as one can e.g. do this in init code
and the UI will take property.userName, ip, password and do Digest auth, and of course display the picture / video.
But the code for buttons can't access to the picture session, so one need to open another one for buttons, and yeah, of course 401.
Anyway, i thought i share my fail with you all ^^
keep smiling ... must be sunday.
first recognized it in QA, tested again with scene and same result
overflow in math.randomseed, everything above os.time()^3 gives same result, always:
/monthly_2020_07/image.png.6345b7b344dd396c8a7d498542384154.png" />
i was using this on HC2, without issues
changed my code now to math.randomseed(os.time()) and no issues, so in same someone else is using it, be careful^^
For all who need MD5 and/or Digest Auth on HC3, i made sample QA which implements following things:
  • Digest Access Authentication
  • MD5
  • example of send with button click
  • example of loop send
  • HTTP and HTTPS
You can find it on our
This Quick App is btw. part of upcoming Dahua Doorstation QA, which i hope will support as well DHIP protocol, to e.g. allow triggering on call
EDIT:
Edited by tinman
Asking too much personal data for a free example... Not my coffee...
Keine Bezahlung nötig für diese Bestellung
und weiter:
Bitte wählen Sie eine
und akzeptieren Sie unsere
So ist es unmöglich es herunter zu laden
Edited by Bodyart
we can make paid example for you if that helps?
Honestly i'm not store admin, it is for free, so what, nobody is forcing you to use your real name/email
It's not possible to download at all
Ich kan überhaupt keine Zahlungsart wählen und Zahlungspflichtig bestellen is thus unaccesible...
Edited by Bodyart
@Bodyart HC2 use MD5 \opt\fibaro\plugins\com.fibaro.philipsTV\md5.lua
@10der,
i like that fish :-D
indeed .. wtf .. anyway, posted above the QA
Thanks @tinman for checking with me and for posting the QA here. Appreciate very much. I hope that my feed back will help to improve your site :-D
Edited by Bodyart
sure, already forwarded to shop admin, i can only click "next next next" and hope it works :P
Nope ?
2 hours ago, Macschimmi said:
Nope ?
i know, got already answer "it looks like some of the modules in store breaks the "for free" feature, so you have to add with price x and " ... exact, and that part i stopped to listen and removed all non-working for free QAs from store till it's fixed. They now directly free to download on quickapps.info website
Edited by tinman
Does anybody know how to add icon to centralSceneEvent to show icon in History panel (currently there is only "undefined")
    In the
    there is a module for event handling that can greatly help in setting up timers and deal with complex asynchronous logic.
    Only 3 functions are added to the QuickApp class
    self:event takes an event pattern and a function to call when an event matching the pattern is posted.
    An event is a Lua table with a 'type' field. Similar to triggers we get back from sourceTrigger in Scenes. But here we can invent our own types.
    Here we declare an event handler for an event of type 'MyEvent' and a function that prints out a message whenever an event of that type is posted.
    This will post an event immediately - and the event handler declared previous will be called.
    This will post the event after 60s. It's very similar to setTimeout. However, the time can be specified in a string format
    This makes it useful for scheduling timers.
    self:post returns a "timer" that we can use to cancel the post if it hasn't been posted yet.
    One way to think about :event and :post is that's it like declaring a function/subroutine with :event and call it with :post
    We can think about the fields in the event as "arguments"
    Well, we don't want to only add 4 and 5, we would like to add any numbers
    It turns out that an event pattern of {type='add'} matches an event {type='add', x=4, y=9}
    As long as there is no fields in the event that contradicts the pattern it matches. It's allowed to be additional fields in the event.
    However, a pattern of {type='add', x=4, y=9} doesn't match an event of {type='add'} because there are fields missing (x and y)
    That makes the previous handler work. Now we see what the 'env' parameter for the handler function is for. It returns an "environment" with the event that matched. There we can find the x and y fields and add them.
    However, we would like to specify that the event handler expects a x and y fields without saying exact what they are
    We can use value matches. This will bind env.p.x to the value of x and env.p.x to the value of y  ('p' stands for parameter)
    This handler will only be called if there is an x and y field, and as a side-effect we get the values.
    The value matches can help us to constrain the matches
    This will only match if x == y because both matches to the variable 'x'
    This will only match if x and y is bigger than 10
    We can easily create loops
    This creates a handler for the loop event. It prints a message and post a new loop event 10s in the future. That will then trigger the loop and it repeats indefinitely.
    The last self:post is to start the loop by posting the initial loop event.
    Som examples
    Loops that use "t/<time>" and "n/<time>" will not drift as they are scheduled on an exact time. However, "+/<time>" and time as a number of seconds may make your loop drift as the execution inside the loop will take some time. So your loop that you schedule every 10s actually takes 10.01 seconds and it adds up over time..
    We can create a loop that compensate for drifts by scheduling using epoch/unix time as reference.
      It's becoming a little bit more useful than setTimeout...
    There is a helper function defined to make net.HTTPClient() requests. It will post an event with the success or error result. This way we can structure the callbacks like event handlers instead. The self:HTTPEvent adds some extra functionality like basic authorisation and easily set headers etc.
    The 'tag' filed can be useful for matching up handlers with requests if you have different types of request in the code.
    With events it's easy to do state machines (automatas) to handle complex state transitions in an app
    I find it nice to structure the program as a "state machine" or "automata" in this way. The code structure becomes rather "flat",  with just a list of different handler reflecting what state the program is in. With traditional model and callbacks the code tends to easily become deeply nested.
    With the triggers module, HC3 triggers will be posted as events and we can pick them up with the same types of event handlers'
    The event format tries to follow the Scene sourceTrigger format.
     However, wee need to enable type of triggers we want to receive to avoid being flooded, by using self:enableTriggerType(<list of types>)
    We have seen that we can match variables with '$<name>' as an event value. '_' means any name.
    We can add conditions/constraints to the match like this
    Actually, device events are specially treated and allow us to make match against list of IDs
    Lets make a light that is turned on by a sensor, and turned of when sensor been safe for 5min
    Here we use self:cancel for the first time to cancel an eventual post when the sensors is breached as we want to "restart" the watch. We start the timer when the sensor is safe and set its expiration time 5min from when it become safe.
    Note, In the 'safe' handler we see that self:debug can print out the timer in a readable format that tells us when the timer expires - very useful for debugging.
    We can easily  generalise the code above to watch any number of sensors independently:
    So, with only 3 functions self:event, self:post, and self:cancel we can create quite complex code, scheduling timers and handling asynchronous events. The basics for home automation...
