1 hour ago, tinman said:
so it's important to close the socket (to stop the binding made by the QA socket) after one received the data.
My need is continually receiving UDP broadcast messages sent to a specific IANA registered port (3639) - so that's just not possible yet in HC3 ?
send possible to ANY addresses
but you can rcvd only via port what provide @tinman
just bind HC3 IP and magic port from Tin
I need to receive UDP messages that are being sent by other external devices to a local broadcast address
e.g. 192.255.255.255  on port 3639  I can't alter that 3639.
Fibaro need to include the capability of adding the required port to their firewall I think.
Edited by xAPPO
- solution 1 - wait till Fibaro allow that
- solution 2 - buy raspi and configure it as UDP forwarder
    ... and meanwhile I can practice UDPSocket with
    . However, I think it works better in the emulator than on the HC3 at the moment :-)
    Gives output:
    Nice.... jealous
    i notice in your QA toolkit you have a currently commented out method to allow a QA device type to be changed after creation..  is this something that might be doable ?
    1 hour ago, xAPPO said:
    Nice.... jealous
    No, unfortunately I don’t think so.
    Interactive push works (sometimes,. I got some errors)
    Anyway, we can now do an interactive push in a QA that makes a callback to a function of our choice if the user press Yes. This was a bit more complex on the HC2.
    • Thanks 2
    does anybody know how to delete local QA variable?
    Edited by petrkl12
    Something like this?
    However, the QA will restart when you do the api.put.
    Thanks. It’s a pity that there is restart ...
    It would be interesting if we could agree about a format for sharing tried and trusted code in this forum.
    We have the "files" concept for QAs and we can call QA functions from scenes.
    I see 2-3 kind of demands for sharable code.
    1. To be able to include code in your QA by importing/copying "files".
    1.1 To decide order of files loading
    1.2 To avoid polluting the global namespace with functions from included files - e.g. some kind of module concept.
    1.3. Some mechanism for versioning, like meta-data
    2. To be able to remotely call functions residing in "QA libraries", something necessary for scenes as they can not add/include "files".
    3. Some kind of audit/governance so that code could be deemed trusted.
    1. Here, it would be nice to control the load order of "files" - lets call them modules - because we can't guarantee the "load order" of files (except that .isMain seems to be loaded last).
    One approach is that each file keep all their functions inside a initialiser function and add the initialiser to a global
    Then the main function could load each module in the order it wants to load them, or load them on demand.
    We could also add more meta-data
    and loading like
    Then it would be easy to create add-ons that copy files from a library QA and keep files updates etc.
    2. Remote function library.
    It's easy with the possibility to call QA methods with fibaro.call(<QA id>, <method name>, <args>). This is the only way to get access to shared functions from a scene (without patching the code).
    It's a bit trickier to return a value.
    . Best would be if Fibaro allowed fibaro.call/getValue to return values.
    The approach would mean to package the functions in QA that makes the functions in them available for remote calls (and they could use 1. to update their "files")
    It would be nice to be able to have a library that could be both used as a sharable file - and as host for remote functions (the same functions)
    In any case, remote function libraries are interesting because they allow share "services" with state - like loggers etc.
    3. If Libraries where shared as QAs in the download section, 'likes' could be a sign of trust. Would also be nice with some common repository with an "installer" QA that downloaded and installed shared code and helped with updates.. Kind of an apt-get for the fibaro community.
    ...anyway, some first thoughts.  All the mechanisms are there - just need to agree how to share code and best practices.
    I am waiting while @A.Sochaand Fibaro dev will add return value(s) to fibaro.call
    cuz it’s first and last right method to have and call shared code AKA libs
    IMHO
    No guess why json response from get/post what translated by fibaro.call method now routed to /dev/null
    Some time back I coded a Lua interpreter using the limited environment we have on the HC2 (no parser libraries etc). It compiled to a "nested Lua functions" representation that is a relatively simple way to create a backend for a runtime. However, because it uses Lua's own stack for its nested calls it's very difficult to "pause " the execution to implement something like coroutines. So I have enjoyed myself to recode the backend for a home-made VM with a classic "flat" code + stack structure. This means that the new version have both coroutines and metatables.
    The main file in my test QA looks like below and runs a couple of tests - coroutines, metatables, http etc. The QA UI has 3 buttons, to run the code in main() with different types of debug flags. (Note that everything within "function main() ... end" is compiled and run by the interpreter). In a way it's kind of a mini IDE inside the existing QA IDE... :-)  (and it's powered by the "
    " that makes the QA structure easy)
    Note how the HTTP example can wrap the asynchronous net.HTTPClient():request and present it as synchronous calls to the following two "local code,res = httpRequest("http://worldtimeapi.org/api/ip")".
    An example of all bells turned on for a simple piece of code looks like:
    ..with trace:
    If I run a speed comparison between some "real" lua code. A 'between' times function coded in "native" Lua and one version loaded into the VM.
    I get a speed diff around ~40x - it varies of course due to the type of code. Note, that the emulated version of 'between' takes ~1ms, which is still pretty fast. So I believe it's usable...
    Besides it being fun to implement Lua with all it quirks this could be used as a base for scripting rules - like ER. The advantage with coroutines is to be able to sleep/wait without blocking code - something I have in EventScript, but this becomes a much more general model. Ex. overlaying a fibaro.call that returns values etc. It would also be possible to implement a real debugger and allow to step through the Lua code...
    Anyway, it's fun :-)
    Here is the code
    • Thanks 2
    @jgab
    oh my god...
    Thats when hardware developers is lazy.
    we want hook events in QA?! Building own bike
    we want shared library for all QAs? Yes building own bike
    We want .... sure!! Building own bike
    that’s Fibaro, isn’t it ,
    @A.Socha?
    A small trick that can help in debugging.
    When your code crashes in json.encode/decode the error message is a bit lacking...
    or
    The problem is that we only get the information that json died somewhere inside its code... not very helpful. It would be better if we knew what line in our QuickApp that called json when it died.
    This will patch the json functions so that they report the line from where they were called. I have found it to be very helpful...
    • Thanks 2
    I have some strange behavior of a QuickApp to retrieve information from the SENSOR.COMMUNITY. I don't know if it is the
    or the source code ??? The SENSOR.COMMUNITY site does now and then doesn't give an answer.
    This is the result, with an interval of 5 seconds, a successful "beep" followed by an error but immediately followed by a successful beep:
    I have removed the most from the source code, to reduce faults. This is the remaining code:
    Edited by SmartHomeEddy
    @SmartHomeEddy
    The reason will probably be server overload. Because you have a timeout (HTTPclient) of 5000ms, you will get an error message. If I tested it on a question, in several cases I received an answer after 30 seconds.
    Maybe try to replace  your self:debug("beep") to self:debug("response status:", response.status). See if you get any codes other than 200.
    Edited by Martin_N
