HC3 QuickApps coding - tips and tricks
jgab
  • 42 minutes ago, SmartHomeEddy said:
    After
    Code that works ...works, but...
    Just a general coding reflection - feel free to ignore.
    You have a function that is named setGlobalVariable that actually deletes the variable if a global variable 'setglobalvar' is false... ?
    It may look like a clever Swiss-army-knife function today but in a year you will wonder "why do I call 'setGlobalVariable to delete variables?" and chasing bugs because the global 'setglobalvar' happens to have the wrong value...
    I would split it up in two functions - the first similar to my example but with the extra json encode (and it's a bit more efficient as it doesn't need to call api.get for every setGlobalVariable call as it cache that it has seen the variable) and then a separate deleteGlobal function that does just that.
    The code grew upon testing ? If someone decides not to use the variables anymore, then I have to delete them.
    done
    On my ToDo list, first I try to understand that code
    Edited by SmartHomeEddy
  • Just a reflection on speed of different ways to store values - local Lua variables, global Lua variables and fibaro globals (QA quickVars seems to be similar to GVs)
    The timings I get are
    The comparison between Lua variables and GVs are not exactly comparable but it gives some rough proportions anyway.(It would be even worse (>2x) if we incremented a fibaro global in the loop)
    First note that Lua globals are much slower than Lua locals. Note that 'fibaro' in ex. fibaro.call is a global. Locals are good - and because they are scoped there are less risk that you have unintentional effect due to globals overwriting each other...
    Fibaro globals are ~4000x slower than a Lua global (getting a bit faster than setting). Implication of that is to keep values in Lua variables and treat fibaro globals as a storage/persistence and don't ex. access/set them in loops if you can instead read before the loop and update afterwards - or at least update after the loop.
    No worries - I been overpowered by code many times - just need to find the strength to fight back...:-)
    Jan, persistent storage if we talking about Fibaro is SQLite. Idk why global params is too slowly as you said 40000x
    Well, it's rather that Lua is very fast.
    fibaro API is going through a rest call (It may be internally optimised, I don't know) but in any case there are a lot of overhead. compared to pure Lua.
    - hey boy, what are you doing here?
    - boy, what is you name?
    - are you slowpoke?
    - my name is John
    - where are you living?
    - no! I am not a slowpoke!!
    sometime development with Fibaro UI look like this meme.
    rough 4000 not 40000.
    indeed, all thr pcall, asserts, invokeScenes does not take lot of time, the rest call does however.
    Now imagine all these smart scenes looping while rest called global variable changed :P
    Yes,
    Just to put things in perspective, in absolute time a fibaro.getGlobalValue takes ~1.7ms - so one can read the value 600 times in a second.
    Accessing Lua globals on the other hand takes microseconds.
    2 minutes ago, jgab said:
    Yes,
    Jan remember that getGlobalValue also return for you the tracking value lastChanged. a native  Lua globals not.
    Edited by 10der
    Does anybody know how to setup in QA that device is not connected?
    /monthly_2020_08/image.png.0f5aae7b22de273f4d66e77782419158.png" />
    yep
    example (SonOff device)
    pay attention to
     error = function(err) self:updateProperty("dead", true) end,
    /monthly_2020_08/image.png.0fe0fed60fed5b4b05141845807e8e57.png" />
    Edited by 10der
    On 2/22/2020 at 7:11 PM, jgab said:
    Sharing devices between the HC2 and the HC3
    Yet another hack.
    Here is a HC2 scene - You need to call it "HC3Proxy" and set the variables for IP, username, and pwd for you HC3 in the code.
    Also set "Max running instances" to 10.
    7 minutes ago, Rover said:
    Hi @jgab,
    I did install the scene on HC2 and the QA on HC3.
    Blockscene on HC3 knowns the HC2 devices, but test Toggle HC2 device (switch) from HC3 test blockscene delivers the next on HC3Proxy on HC2 (and no toggle of the [email protected] device):
    Please help me to get it done.
    Edited by Rover
    Hi @jgab,
    I set up a topic with a QD question, but I realize that I should have asked that question here.
    Would you please look at my question?
    I would like to make a QA Child on an existing fibaro double switch.
    thank you in advance..
  • On 8/30/2020 at 4:59 PM, Rover said:
    Hi @jgab,
    Sorry, I missed this post.
    Have you done all the configurations?
    Have you set the HC3 IP/user/password variables in the HC2 scene?
    Have you set the HC2 IP/user/password variables in the HC3 QA? (and setup the table with the devices)
    I don't fully understand this sentence
    "...but test Toggle HC2 device (switch) from HC3 test blockscene delivers the next on HC3Proxy on HC2 (and no toggle of the [email protected] device)"
    Can you elaborate?
  • 1 hour ago, NLWaard said:
    Hi @jgab,
    Just to recap:
    You have a double switch today that is visible as two binary switches in the UI.
    One of those switches control a light bulb that can dim depending on the number of  clicks.
    Correct?
    You can't "attach" a childDevice to an existing z-wave device. A child device needs a QA that runs the code and creates the child devices. We can't add Lua code to z-wave device.
    Why would you like it to be a child device? You want them to group together in the Web UI? (child devices are listed directly below the "mother QA"  that creates them)
    What you maybe could do is to create a regular multilevelSwitch QA (on, off, dim level) that takes the input from the binary switch (on, off) and add a slider for the "dim" value. Then hide the z-wave binary switch. Can you control the dim-value by sending rapid turnOn/turnOff commands to the bulb?
    .... and the next question to @jgab will be
    Jan I can see nothing ;) NO QA and NO physical device in mobile application ;)
    ...but Fibaro will fix that soon - just hold your breath ? ...and when you wake up it will work :-)
    • Like 3
