On 9/3/2020 at 6:54 PM, Rover said:
Why is the first print statement working and the second does not?
function QuickApp:onInit()
    self:debug("onInit")
    self:hello()
    self.jT = json.decode((fibaro.getGlobalVariable("HomeTable")))
    print(self.jT.TestKamer.testLicht)
function QuickApp:hello()
@jgab can you help me?
    Because you are calling self:hello() before you have assigned self.jT the value of your HomeTable. Thus self.jT is nil in QuickApp:hello()
    Refreshing an old discussion.
    If you create your own UI elements for the QA you have a bit more control of the layout.
    it's possible to squeeze in more than 5 buttons in a row (depending on how much text you want the button to have)
    The pop-up works on the phone too. There is also a multi-select version of it.
    The toggle control (switch - box that toggles between blue and white) works so-and-so.
    I'm still playing with the image control and will come back when I figure it out...
    This is the code that I used
    • Like 3
    On 9/6/2020 at 5:20 PM, jgab said:
    Well, I made some tests and it seems like a two things need to fulfilled for a device to be included in an alarmzone
    First it seems to need to have the interface "fibaroBreach".
    Secondly, it seems to have to be a valid device type, like com.fibaro.motionSensor etc. Does anyone know the complete list? Ex. com.fibaro.binarySensor does not seem to work
    I have made a new version of the HC2Proxy that allows you to add a list of interfaces to the device being created.
    v1.4
    You can also add "batter" and "power" and "energy".
    On the HC2 if you trigger on %% property <id> battery the HC3 proxy should be updated.
    Hi jgab
    I tested your HC2proxy quickapp
    Home Center 3 <=> Home Center 3
    Control is possible
    Below screen
    How can I synchronize?
    Edited by minsad79
    Just now, minsad79 said:
    Hi jgab
    Control is possible
    Below screen
    The current code relies on a scene running on the HC2 pushing changes back to the HC3.
    For HC3<->HC3 there need to be another type of logic. It's possible to make something similar (a QA on the HC3 that pushes values to another HC3).
    But wouldn't the HC3 be  able to use other HC3s as slave devices? (I only have one)
    The gateway mode function is not available yet
    I don't know when fibaro will do it
    I inquired because the device of hc3 is not sync
    HC3<=>Can you develop HC3 synchronization function?
    attempt to call a nil value (method 'getView')
      local v = "4"
      if self:getView('lt','text') ~= v then
      local v = "4"
    Yes, it uses my
    code (and I build and deploy it to the HC3 with the hc3 emulator). The Toolbox_ui module is a new module under development. I will upload it asap.
    Here is an assembled version
    New version of the HC2Proxy that should work with sceneActivation devices like remote controls
    HC2 scene
    I've installed on both sides HC2 & HC3, but instead of plenty childs (+/- 15) i have only 3. Can't figure out where to search...
    HC2 scene
    Is there a way to connect with HCL? Maybe after changing the firmware -
    Yes, only if you can run the scene on the HCL.
    You need to go into the QA (main file) and edit this table
    -The number is the device number on the HC2
    -Name is the name the childDevice will get (you can change it later)
    -class is the available child device types supported. binarySwitch, binarySensor, multilevelSwitch, multilevelSensor, sceneActivationDevice,..
    -type is the fibaro type the childDevice will get. It will decide the "look" of the childDevice, however, it must be supported by the previous class. A com.fibaro.doorSensor works with binarySensor etc.
    Setup the HC2 credentials as quickVars. IP="192.168.x.y", User="[email protected]", Pwd="xyz"
    On the HC2 you also need too add the trigger in the header for the devices you are proxying
    It's not a priority at the moment....
    Thank you very much for the guidelines, but with version 1.4 I had all defined devices and with version 1.5 only 3 are left, while i copied the PROXIES array to the new QA and also copied the triggers to new HC2 scene....
    Edited by michal85pl
    I've installed custom recovery on my HCL.
    Created Proxy Scene, edited credentials.
    I Have 3 sensors (siren, door sensor/ motion sensor). I Can see that they triggers scene...but i can't see it on the HC3.
    From the HC3 i can turn on/off siren, but i can't see states changes of the other sensors...
    Seems to be a problem on the HCL side? How to solve it?
    problem solved...some bug in HC3 credentials, password changed for the same one, and now works
    I added in HCL:
    %% autostart
    %% properties
    14 battery
    17 battery
    8 battery
    9 battery
    10 battery
    * value
    HC3
    PROXIES = {
    [14] = {name='Syrena', class="binarySwitch", type="com.fibaro.binarySwitch", interfaces={"fibaroBreach","battery"}},
      [17] = {name='Drzwi', class="binarySensor", type="com.fibaro.doorSensor", interfaces={"fibaroBreach","battery"}},
      [8] = {name='Ruch', class="binarySensor", type="com.fibaro.motionSensor", interfaces={"fibaroBreach","battery"}},
      [9] = {name='Temp', class="binarySensor", type="com.fibaro.temperatureSensor", interfaces={"battery"}},
      [10] = {name='Lux', class="binarySensor", type="com.fibaro.lightSensor", interfaces={"battery"}},
    But still got 0% batt
    /monthly_2020_09/1522058848_Adnotacja2020-09-09202149.jpg.31f74cb191f0245d52b76b8edc740296.jpg" />
    what I missed?
    Sorry, the interface is named "battery", but the property is "batteryLevel"
    %% properties
    14 batteryLevel
    etc
    %% properties
    14 batteryLevel
    etc
    changed but still 0%
