@tinman just i have re-written class. remove all UI ref + create save / restore methods
4 hours ago, 10der said:
I have patched @tinman code with separated "device"
now
dev:playFromCIFS
or
dev:playFromUri
not removed the current queue playing.
so if you now listen Ozyy Osbourne and HC3 playing notification now it lok like
Is the local dev not getting IP-address in function QuickApp:onInit()?
no. cuz i can call ANY sonos and pass any IP addresses what i want to play
+ can seek
+ save / restore (also queue)
playFromCIFS
and
playFromUri
now always auto save the current state / queue / etc
% known bug - volume not saved but can't changed by playing playFromCIFS & playFromUri. TODO
Edited by 10der
2 hours ago, 10der said:
+ can seek
playFromCIFS
and
playFromUri
Is it a scene or a QA?
How to call this scene?
It’s raw code for any.
you can make from code or scene or Qa
but probably it should be Qa
well will do
[violation of copyright]
sorry @Tinm
Edited by 10der
1) upload QA.
2) save.
now from anywhere
somehow I can’t get it to work. It only plays the first second of the mp3 ?
(Start and stop do work)
Edited by SmartHomeEddy
this is why i decided to not count on timers in my QA, state trigger is better for that (or state change check in loop). State check is separate loop, so one can specify even .25 for 250ms update, so as long your Sonos can handle it, you have the state change in time.
from NAS should be OK
if you playing from URL - SONOS do not return me how many time i should waiting for the end.
Sonos always return me 0:00:00
I do not know how to fix it.
may be I should loop here... and wait IDLE state... but i do not know.
i can test when i back top home
Edited by 10der
I use a local NAS. (I also tried from a web url, but no sound)
The mp3 I use, is almost 2 seconds.
no worry
no worry
can you check is changes somthing in teh queue?
maybet you wrong provide path?
The Sonos plays only the first part of the mp3. So I hear what she is trying to say ("You have got mail"), but she stops after "You" ?
(The MP3 is included in this post)
So the path will be OK then?
sorry @Tinm
Edited by 10der
Is there a way to extract the Lua code from the fqa?
(I like to copy past the Lua code)
using io.open and io.write at ZBS or VScode
sorry @Tinm
Edited by 10der
Thanks @10der, I am at work right now, I can't hear what Sonos is saying at home ?, I will listen to her end of the day.
Thanks, I have VScode (don't use it that much). I will try to figure it out.
(Would be nice to learn from several codes, without having to install the QuickApp)
@10der The whole MP3 play, from begin to end. I expected after playing the MP3, the music station playing before the MP3 would return. But the Sonos turnes off, or mutes. If I push play, the MP3 is played.
Or do I have the wrong expectations?
No. Strange
radio station - have a mail - radistation again
ok will check
